Disable seatbelt chime
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
I would like to know how to disable my seatbelt chime. If the answer is "wear your seatbelt" or similar, please save your breath. I was able to disable my 08 Jeep's with an ignition seatbelt sequence which disabled the chime. Any ideas for the Acura ???
07 TLS
07 TLS
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
runnin a little boost
I thnk Honda has been using the same one for a long time. All the system needs is that piece to contact. I would look for the airbag fuse too since you don't want that hitting you with no belt on.
Acura uses two stage air bags, only one charge goes off if you don't have your seatbelt on or the seat is too close to the wheel. Two charges go off if the system thinks you are belted up or sitting farther back.
Two charges will brake you off good, if too close at impact. Look in the 3rd Gen garage for the fuse to take out and the buckle should be cheap.
AZ Community Team
Received 7,771 Likes
These threads NEVER end well and no one here is going to be liable for you ending up maimed or dead.
'07 TL-S
joflewbyu2
10-08-2015 11:16 AM
