Deep Creep in wrong hose!
What are the hoses linked to that are positioned before the throttle plate on the right hand side looking at the engine? (Between airbox and throttle body) Not the vacuum port as i have found out!
I sprayed some deep creep down there and car stinks like something is burning bad!
My own stupid fault, just not sure where it goes!?
Sorry i cant post pics from this computer!
Here is a thread which shows the hose i sprayed into. looks like the crankcase ventilation hose! wonder if that will cause me problems??
https://acurazine.com/forums/showthr...y+coolant+hose
First, no reason to ever use that stuff in a TL....ever.
You sprayed it into the fresh air side of the PCV system. In short, you sprayed it into the engine oil. I don't know how much you put in there but I would change the oil asap.
