Dash board bulbs out
I have a bunch of lights out in my dashboard (hazzard, VSA, volume control/channel control and call button on the steering wheel) that I'd like to replace..... My question is where can I het them and does anyone have a write up on how to get the dash apart to get to them. Can I convert them to LEDs so I don't have to deal with these Damn bulbs going out on me all the time? If so where can I get LEDs for replacement dash lights...... Thanks
There's a write-up in 3G garage for the LED swap....lemme see if I can find that link.Personally I'm trying to switch to blue. (similiar to how the type-S is all red)
G-100: DIY: LED Lighting For your TL!https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-0-retrofit-oem-bayonet-housings-led-747846/ - Part 0 Retrofit of OE Bayonet Housings with an LEDhttps://acurazine.com/forums/showthread.php?t=746609 - Part 1 Map Light Consolehttps://acurazine.com/forums/showthread.php?t=746947 - Part 2 Rear Door Window Switch w/ Handle LEDshttps://acurazine.com/forums/showthread.php?t=763640 - Part 3 Steering Wheel LEDs (Audio and Cruise Modules)https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-iii-steering-wheel-746972/ - Part 3 Overviewhttps://acurazine.com/forums/showthread.php?t=747870 - Part 4 Center Ventshttps://acurazine.com/forums/showthread.php?t=747874 - Part 5 Cluster Console (EASIEST OF THE BUNCH!)https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-vi-front-passenger-door-w-rl-door-handle-led-750657/ - Part 6 Front Passenger Door w/ RL Door-Handle LEDhttps://acurazine.com/forums/showthread.php?t=750671 - Part 7: Front Driver Door w/ RL Door-Handle LEDhttps://acurazine.com/forums/showthread.php?t=750880 - Part 8: Knee Panel Lights (VSA, Mirror, etc)https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-ix-heated-seat-switches-755070/ - Part 9: Heated Seat Switcheshttps://acurazine.com/forums/showthread.php?t=755388 - Part 10: Cupholder Illumination!^^^This should be what you're lookin for. (I haven't read through them in a sec, but I believe it has the explanations for dash removal in there)
monazzim (10-19-2011)
You can't edit like a certain time after you posted (I think 15 minutes?)
If you want to just replace your bulbs, you don't need to solder anything. You can just buy the bulbs online (delray acura, oemacuraparts, etc) and replace the burnt out bulbs like you replace a light bulb in your house (plug and play...)
I had to replace some bulbs, too.
Replacing the bulb is easy (twist old bulb out, twist new bulb in).
Getting to the bulb is the harder part.
Super bright LEDs sells instrument lights but I don't know which ones fit and will work. I wanted to convert all the dash lights to LED but I don't want to solder and these seem like they may work
http://www.superbrightleds.com/cgi-b...nstrument.html
Only reason I haven't done them is mainly fitment. Wanna make sure I get the right sizes. Definately think there are options that don't require soldering. I think the Super Bright LED's may be the way to go.
