Cylinders 3 and 5 not firing
Old 07-01-2013 | 11:09 AM
bungln's Avatar
Hell I can't even figure out which ones they are. anyone got asny ideas what would cause this and which cylinders they are?
Old 07-01-2013 | 11:45 AM
nfnsquared's Avatar
firewall
123
456
radiator
The following 3 users liked this post by nfnsquared:
AccordFlex (07-01-2013), Jiren (09-10-2020), justnspace (07-01-2013)
Old 07-01-2013 | 11:57 AM
I hate cars's Avatar
How did you determine they're not firing? If its misfire codes they will usually be mostly working but have a misfire from time to time such as at idle when cylinder pressures and effective compression are down assuming its due to low compression. It's either fuel, spark, or compression lol.
Is this a manual transmission?
Jiren (09-10-2020)
Old 07-01-2013 | 12:42 PM
AccordFlex's Avatar
I bet you its loose spark plugs... they are notorious in these engines, especially cylinder 5.
Have you ever had your spark plugs changed? What is the mileage on your vehicle? If you have not, I would start there. If not, you will most likely need to replace them, and have a helicoil threaded in your cylinders. Then you will need to scope into the cylinder head and make sure there are no chunks of old thread, spark gapper, or spark plug diode inside there. Your best bet would be to spray some brake cleaner inside of there and vacuum everything out and repeat this at least twice. Then check the valves to make sure that no pieces of metal adhered to it. Otherwise you may need new valves if you didnt catch this in time.
Old 07-01-2013 | 01:51 PM
bungln's Avatar
My engine light came on so I took it to autozone and they put they code reader on it. It said no spark on cylinders 3 and 5. Not sure how they could read that without the car running? The car has 77k miles on it and the plugs have never been changed. seems funny that 2 of them would go bad at the same time tho.
Old 07-01-2013 | 02:05 PM
erdoc48's Avatar
06 Anthracite TL
They can read it because the codes are stored (engine does not need to be running to check CEL codes). Importantly, other than the CEL, does it run properly, or do you hear any tapping noises at the engine?
Old 07-01-2013 | 02:15 PM
bungln's Avatar
checked the plugs, tight and seated correctly. I'm leaning towards the coil packs. The car is aan automatic
Old 07-01-2013 | 02:17 PM
bungln's Avatar
no tapping or otherwise weird noises. Was running great and I came back from a 300 mile car trip in the rain and then all of the sudden ran like crap with the engine light on.
Old 07-01-2013 | 02:22 PM
Has the windshield ever been replaced? Were you running the AC or defrost?
Old 07-01-2013 | 02:25 PM
bungln's Avatar
not that I know of on the windshield. I was running a/c, it was 85 degrees and raining.
Old 07-01-2013 | 02:51 PM
Project_CLean's Avatar
MMkay.
check the connectors to the coils. If there's an exposed cable or dirty connection it can cause some problems.
Also, you didn't run out of gas did you?
Old 07-01-2013 | 02:57 PM
pohljm's Avatar
I vote for resetting the MIL and seeing if it comes back. maybe nothing at all. How does it drive? if 2 of 6 cylinders are not firing it would be painfully obvious.
Old 07-01-2013 | 03:05 PM
bungln's Avatar
nope no gas problems. had 1/2 tank left when it happened so I think I can eliminate bad gas.
Old 07-01-2013 | 03:08 PM
bungln's Avatar
it drives like it's miss firing. steady, no difference whether I floor it or just cruise, still runs rough. How do you reset the MIL?
Old 07-01-2013 | 03:16 PM
erdoc48's Avatar
06 Anthracite TL
One more piece of data- what's the actual codes (the numbers from Autozone) that were thrown? That would help in the diagnosis quite a bit.
Old 07-01-2013 | 03:30 PM
bungln's Avatar
he didn't actually give me the codes, just said the reader said no spark cylinders 3 and 5.
Old 07-01-2013 | 03:36 PM
erdoc48's Avatar
06 Anthracite TL
Take it back and get some actual codes- CEL lights when read give a specific diagnostic code, not just that those 2 cylinders weren't firing. The numbers would be really helpful.
Old 07-01-2013 | 04:20 PM
bungln's Avatar
yeah I can't believe I didn't get the codes, brain cramp I guess.
Old 07-02-2013 | 11:48 AM
bungln's Avatar
the codes were p0303 p0305 p0306 hope that helps.
Old 07-02-2013 | 02:56 PM
pohljm's Avatar
Those are misfires on 3,5 and 6. Is this a manual? sure sounds like an over-rev. or possibly a MICU / ECU with some water
Old 07-02-2013 | 03:02 PM
MMkay.
That's just misfires on 3-5-6.
Question, when you "checked" the spark plugs, did you actually pull them out of the motor? I wonder if your problem is as simple as needing a spark plug replacement.
Old 07-02-2013 | 03:16 PM
MMkay.
Without more information, it can be sooo many things.
I would: Visually check spark plugs,check for spark or Clear the codes >swap the misfiring coils with other cylinders>check for misfires and see if the misfires follow the bad coils..to start with.
Spark plugs
ECM
Coils
Injectors
Map sensor
Vacuum leaks
& More..
Old 07-03-2013 | 09:17 AM
bungln's Avatar
no it's an auto. any idea how to dry out the ecu, or where it's located so I can check?
Old 07-03-2013 | 09:18 AM
bungln's Avatar
no I didn't pull the plugs out, I will.
Old 07-03-2013 | 09:32 AM
the ECU is located underneath the center console.
Under the A/C, Nav, radio stack.
Old 07-03-2013 | 10:24 AM
bungln's Avatar
well that looks easy to get to! LOL!!! But how can that get wet?
Old 07-03-2013 | 10:26 AM
one of the question in the thread asked was, "were you driving with the A/C on"
there is an A/C drain tube that occasionally gets clogged. and guess where it conveniently drips onto?
we have ruled out the "6mt and over-revving"
we have ruled out loose spark plugs.
Old 07-03-2013 | 10:50 AM
bungln's Avatar
I drive with my ac on most of the time so that makes sense. would drying it out reset it or do I have to have someone reset it?
by the way thank you for your help.
Old 07-11-2013 | 05:08 AM
bungln's Avatar
ok finally got around to working on this again. I decided to go ahead and replace all the coil packs and plugs. But WTF? the number 3 coil pack was melted to the wall and I can't get it out. the top of the coil pack broke of when I tried to remove it. Has this happened to anyone else? how did you fix it? I'm pretty handy and don't wanna take to dealer. Also I read that the a/c drain tube could of caused this by dumping on the ecu? HELP!!!!!
Old 07-11-2013 | 06:27 AM
MMkay.
We already helped.
Did you check the ECU like we said to?
Old 07-11-2013 | 06:28 AM
you found the culprit!!
water dripping onto the ECU causes the coil packs to melt!
break off that coil pack and replace it!
you might want to check the ECU and get that A/C drain line unclogged.
Old 07-11-2013 | 08:06 AM
MMkay.
Old 07-11-2013 | 03:07 PM
bungln's Avatar
does anyone have any tricks on how to get the melted coil pack out? is it a "just fuck with it" till it comes out or has anyone had any luck with this?
by the way, a big thank you to all that helped me this.
Old 07-15-2013 | 08:33 AM
bungln's Avatar
anybody?
Old 07-15-2013 | 08:43 AM
^i mean, its held on by a hex head bolt. if it has melted, and cant fit a hex head or an allen key, I would be trying to pry it off, even breaking it to get it free.
you're replacing it, anyway. might as well go the brute force way.
Old 07-15-2013 | 10:31 AM
bungln's Avatar
the problem is the head was already broke. it's the tube I can't get out.
justnspace (07-15-2013)
Old 07-15-2013 | 10:34 AM
yikes, looks like you'll have to manipulate it in some way so that it will come out.
needle nose Pliers?
Old 07-15-2013 | 03:45 PM
MMkay.
Angled needle nose pliers for suree. Twist back and forth until it comes out.
Old 08-30-2015 | 07:53 PM
2004acuratlgreen's Avatar
Follow this procedure to determine if a coil pack has failed on an Acura TL 2004-2008
When you discover your engine is running rough and continue to drive it after the flashing CEL illuminates your computer is registering multiple failures.
Clear CEL, start the car and run till your CEL re-illuminates, then immediately shut the engine off and read the CEL. This process will give you a clean reading on which coil pack has failed. Using this method, as it has been the case on three separate occasions. I then replaced the CYL. # 5 (P0305) with a new coil pack and problem solved.
This procedure has worked three separate times to identify the right coil pack for replacement. Hope that helps on coil pack issues. Later
Jiren (09-10-2020)
Old 08-31-2015 | 10:18 PM
nfnsquared's Avatar
If you've had to replace 3 coil packs, you might have a bigger underlying problem\s....
Quick Reply: Cylinders 3 and 5 not firing
