Current draw from interior lights circuit
Old May 12, 2016 | 10:07 AM
NatGuard804's Avatar
9th Gear
So a while back I noticed my battery was having issues when the car would sit for a while. It seemed fine after long drives so I figured the alternator was good. I replaced the battery and the issue persisted.
Long story short, I used a current testers and found that there was a draw on the battery with the ignition off. I pulled fuses until I found that the circuit for the interior lights was the culprit. I have since left that fuse out without any more problems. Apparently that circuit also controls the keyless entry system.
Electrical draws can obviously be a huge pain to diagnose, so I was wondering if anyone had a similar experience and found the cause.
Thanks!
Old May 12, 2016 | 10:12 AM
the HFL is a known cause of parasitic draw.
check the Hands Free Link Module.
Old May 12, 2016 | 10:26 AM
9th Gear
I'll check it out. Thanks!
Old May 12, 2016 | 01:03 PM
WDPanda's Avatar
Easiest way is to put your hand on it in the morning with the car off overnight. It shoulf be warm.
