Crap! P0420 & P0430 codes
I just bought the car (07' Type S) last week. I put regular gas in it not knowing better (one tank). Think that caused it? I have read all the threads on here about these codes. I going to call the dealer to see if the convertors have been replaced. I think the dealer may have cleared codes just to sell the car...I live in central Florida. Just in case. Where can I o for a good deal to have the convertors replaced if I have to?
If you are receiving both codes I would look somewhere else. I doubt both of your 2 Cats went bad at the same time. Look at something upstream like O2's or MAP.
Edit: You may be able to find some used cats here when users replace for PCDs or HFPCs. |
codes
I would agree. I find it hard to believe both go bad at the same time...
Meh, I'd put some octane booster in your tank (if the normal gas is still in there) and then fill with premium when it runs low, clear the codes and see if they come back.
I certainly don't think its time to worry yet. Were the codes present when you bought the car? |
Simple just put in 93 gas but don't put full tank put like 20$ and just keep doing it for like 2-3 time and just clear the code
Shouldn't be there no more Sould u could burn that cheap gas from the systerm |
reset the CEL and see if it comes back. sometimes the CEL will trip for this if you get a bad batch of fuel or if the sensors are reading off.
Go to acura and see if you car needs a pcm update
Latest Software update released by honda should fix that issue |
Originally Posted by slper
(Post 15182524)
