Crank Pulley Vibration
Searched but did not find anything, my crank pulley is making a noise and also my car is shaking in P,D,N,R shaking/vibration goes in and out. Will a bad crank pulley cause vibration on these cars? I know in some cars it is used to balance
BANNED
i'm not sure how to answer your question, but i do have a stock crank pulley taken off of my 2007 acura tl-s in perfect working order.
let me know if you're interested.
email me at aawiseguy AT gmail DOT com
To clarify.. the crank is internally balanced and the pulley has an isomer that helps reduce vibration. So, if it were truly your crank making the vibration, you dun goofed.
If it's just a vibration through the driveline.. check your mounts including your transmission mounts. Also give us the full specs and symptoms from miles, noises, maintenance history, etc.
Bearcat94 (12-15-2011)
AZ Community Team
Received 7,771 Likes
Also check TSB's for a variety of issues that create various noises in that area.
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
MrHeeltoe
20
02-23-2023 01:54 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
