Compression?
Old Feb 11, 2012 | 07:58 AM
kdogtooth's Avatar
4th Gear
Compression?
what is the cylinder pressure for a 2004 tl 3.2?
Old Feb 11, 2012 | 08:17 AM
vill0169's Avatar
AZ Track Whore
that's pretty hard to just throw out a number. Most important question is are all six cylinders around the same number?
why are you asking?
Old Feb 11, 2012 | 10:56 AM
kdogtooth's Avatar
4th Gear
Refer to 1-26-2012 post. Have car back now and put oil in cylinders. All are 140 to 160 and an acura expert on another site says it should be 210.
Old Feb 11, 2012 | 11:15 AM
I hate cars's Avatar
A 20lb difference is pretty large. As it was said, the most important thing is that they're all close to the same. If the test is done with the throttle open as it should be, the number will be higher. With the throttle shut it will be lower. Even battery condition and cranking speed will have a small effect. Doing the test will all spark plugs removed will give a higher number. What was the original problem and what effect did the oil have on compression.
Old Feb 11, 2012 | 11:34 AM
You should include a link to your original post. Now that I've found it, you have other problems. 125 psi should allow it to start. More importantly the car would not start and not continue to run if it were compression. The faster the engine turns the more compression its going to have so once it starts it should stay running. 125 or 160psi should be enough to run. If compression was the main problem you should see misfire codes whenever the car was idling.
If it was running fine with no prior symptoms and just died and had low compression I would check that it didn't jump a tooth on the timing belt. Make sure vtec is not engaged but I believe it would still start even with it engaged. Fuel fouling the plugs while cranking is usually low compression or ignition timing way off. If it were ignition you would have at least an occasional backfire, pop, or kickback while trying to start it. If by fuel fouled you mean they were just wet with fuel, thats normal if the engine does not start. Hold the throttle all the way to the floor when starting, the will shut the injectors off and put it into clear flood mode.
More details would be nice. Does it make any noise when cranking over, does it turn over faster than normal, does it try to start or backfire?
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
Sep 13, 2015 01:59 PM
