Coilovers seized need help!
Old Mar 27, 2010 | 09:00 AM
MyTL09's Avatar
B A N N E D
so i wanted to adjust my coilovers last night lower and found out that my rear coilovers are zeized (frozen), the front ones are fine. i have nex gt coilovers for 3rd gen and they are dampening adjustable.
any ideas anyone i tried usig pb blaster, and the air hammer gun and i got the bottom ring lose so i turned and adjusted that but the the top one ring or whatever u call it i cant move it at all.
i was thinking of taking the coilover completley out and taking it apart, knowing that the spring is not compressed it will be alot easier, im kinda pissed now because my front is slower then the back and looks kinda GAY!
Old Mar 27, 2010 | 07:53 PM
chinkwapin's Avatar
.:dedicated:.
leave pb blaster overnight and see if that helps. not sure what an air hammer gun is, but try using a regular hammer with the spanner to see if you can break it loose.
ALWAYS apply anti seize to the collars to make sure this doesnt happen again. do it to the fronts too
Old Mar 28, 2010 | 04:48 AM
01tl4tl's Avatar
you should be using a spring compressor tool to remove tension from spring-
otherwise you are fighting a lot of force!
the lower nut is locknut- top nut is the adjuster to move lower plate to change height
should also have a tool that allows you to pull the nuts opposite directions to loosen the locking, but any tension on the spring is your main problem
MrHeeltoe
20
Feb 23, 2023 01:54 PM
ttimberlak443
21
Oct 22, 2016 10:23 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
4drviper
Sep 23, 2015 07:42 PM
