Code P0420 Help Please
Old Feb 21, 2014 | 09:19 AM
tpy1879's Avatar
I have a 2005 TL with about 125,000 miles on it. Should I replace the cat converter or the 02 sensor or both to solve this issue? Advice Much appreciated, thanks
Old Feb 21, 2014 | 09:25 AM
it could be the cat or the 02 sensor.
do you smell sulfur? or rotten eggs by chance ?
Old Feb 21, 2014 | 09:29 AM
EvilVirus's Avatar
Normally, if you get a bad smell its your cat.
Switch the O2 sensor first and delete the code. Drive it and see if it comes back on.
Old Feb 21, 2014 | 09:58 AM
tpy1879's Avatar
It does smell but not very often. Check engine light came on and this is the code it gave me. I did see a change in my fuel usuage though. Should I replace the cat as well as the 02 sensor?
Old Feb 21, 2014 | 10:08 AM
tpy1879's Avatar
I think I should just replace both of them. I've had this vehicle since 2008 and I have never had to replace any of the two since I bought it. I have to do one or both because the engine light won't go away, just wanted to get opinions on it before I spend about $500 on parts unless you guys can help me out on that too. Let me know peoples, once again info is greatly appreciated as a proud TL owner. Thanks
Old Feb 21, 2014 | 10:21 AM
the cat is the most expensive part.
if you do replace something, replace the 02 sensor first!
if i remember correctly, the cat is upwards of $900
Old Feb 24, 2014 | 05:42 PM
BwhiTL13's Avatar
Honda Service Advisor
From acura or honda ive seen cats up to $1400, def go for the sensor firs
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
