Clutch Pressure Control Solenoid Valve A Stuck On
![](https://cimg2.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1504/img_6848_c83a242b8d40ccedea33a134c99d49e771424806.jpg)
![](https://cimg5.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1504/img_6849_4a05519cf539c3d71a8c0d31b9a53199a3ddacff.jpg)
I have 2006 Acura TL. I got my automatic transmission rebuilt a year and a half ago, and I have put on only about 15,000 miles on it. One day, the transmission went into limp mode and I got stuck in the middle of nowhere and drove it home while in limp mode (going 50mph stuck in 2nd gear at 5000 rpm for an hour home). When I got home, I first did the basics: change my transmission fluid, replace the transmission filter, and change the 3rd and 4th pressure switches. I pulled this salvage operation a day before I had to go on a road trip. Later that night, I test drove the vehicle again, and this time it wasn't stuck in limp mode, but it was shifting very erratically. Very hard downshifts and up shifts, almost like it was jumping around gears and couldn't figure out what gear it wanted to be in. I scanned my car, and the intermittent code that kept popping up is "Clutch Pressure Control Solenoid Valve A Stuck On". Now, I've been looking really hard to find the exact location on where this solenoid is but I am not a transmission expert. I'm wondering if simply replacing the solenoid would fix the problem. I've already spent a lot of money on the other parts trying to fix my transmission and I don't want to spend more money that I don't need to. I'm really stuck and I really need my car for commute, I have no other backup vehicles. I wanted to give it a shot and see if I can fix this before taking it to a shop. Really need some help, much thanks in advance. I will try to post a link to a video of my symptons.
Have you tried replacing your CPC A solenoid?
That's what I want to do, but I don't know the location of where this solenoid is. And I was reading that if there's something wrong with the solenoid, that there might be a bigger problem at cause. But I don't want to conclude anything. Is this solenoid on the outside of the transmission case? Or does it require me taking apart the transmission to replace.
Update, found a page in the service manual about the clutch pressure control solenoid valve A/B. I will be taking out these solenoids which are on the outside of the transmission case and test them. However, does anyone know if replacing this is usually the solution?
Same problem...
I have the exact same problem on my 06 TL. Must be a common occurrence. Did the pressure control solenoid fix your problem? I got code P0747 which said it could be dirty fluid, clogged filter or the PCS. The fluid and filter were replaced last month so I'm looking at the solenoid. Please let me know if it helped you.
Same issue
So I'm wondering if you have an update, I replaced the filter and changing the fluid aswell.......anything would help I'm trying to find an easy way to purchase the part
Part number?????
