Clutch master cylinder
Old Feb 20, 2011 | 03:37 PM
speedytypes's Avatar
My question is quite basic, has anybody had any problems with there clutch master cylinder? and if so what kind of symptoms did u experience?
Old Feb 21, 2011 | 07:02 AM
powerflow's Avatar
Wiggy Wiggy Wiggy
I had mine replaced under warranty due to click in the pedal stroke.
It worked fine but I could hear and feel the click.
Old Feb 24, 2011 | 02:04 PM
allykahn's Avatar
Just had mine replaced. Went to start the car and clutch pedal went straight to the floor. Dealer said the part was bent, which I am not sure how that could happen, however it was repaired under warranty. The same thing happened on my 92 Accord 5 spd. I wonder how often this part is replaced?
All is fine now.
Old Feb 24, 2011 | 11:01 PM
Just got the problem rectified today, and it was the strangest thing. The flex hose apparently was stuffed up. My mechanic told me that hes seen it happen on brake flex hoses, where the hose deteriorates and it clogs itself up. He says that is when you sometimes see sticking brakes, its when the brakes cant push away the piston and they drag.
Old Oct 9, 2011 | 08:24 AM
chase791's Avatar
7th Gear
my symptoms on my 2005 tsx when my master clutch cylinder was going out was that the clutch pedal engaged really low causing it to be hard to shift into 1st and grinds going into reverse.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
