Clutch master cylinder
Just had mine replaced. Went to start the car and clutch pedal went straight to the floor. Dealer said the part was bent, which I am not sure how that could happen, however it was repaired under warranty. The same thing happened on my 92 Accord 5 spd. I wonder how often this part is replaced?
All is fine now.
All is fine now.
Just got the problem rectified today, and it was the strangest thing. The flex hose apparently was stuffed up. My mechanic told me that hes seen it happen on brake flex hoses, where the hose deteriorates and it clogs itself up. He says that is when you sometimes see sticking brakes, its when the brakes cant push away the piston and they drag.
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
