Clunk sound on right wheel when going over bumps
Whats up everyone.
Every time I drive over street bumps I hear a clunck sound on my right front tire. I feel as if the tire is not absorbing the bumps. I think maybe I need new shocks, but wanted you guys to chime in, in case its something else.
Apparently no one has a clue... I have the same noise. I was told it was a bad shock, but I don't completely buy it, as I hear the same noise occasionally when I start the car on an incline/slope. While driving it seems to come from the right front corner, when starting it seems to come from the center tunnel forward of the shifter.
Sounds similar to what I have, although I only hear the sound when i go over bumps, not when the car is on idle or running on a smooth surface.
when going over bumps it could be swaybar links, swaybar bushings, strut mount or even the strut itself. if it was a mototmount, you would be able to see the motor moving around when in drive at a stop and brake-torque the engine a little. most likely a swaybar related issue. check your control arm bushings too. unlike, but they move with the suspension. check your lugnuts. could be as simple as loose nuts. another unlikey but possible source is your wheel bearing. not common, but i guess it could go bad.
3rd Gear
Sounds like the problem I had. The mechanic at the garage said it was caused by the Swaybar links and I had them replaced, but it made no difference. I bought the Swaybar bushings on line and replaced them my self. They cost about $5 each and take 15min to replace. Might be worth a try.
I think it is your motor mounts. I get the same noise everytime i go over speed bumps, it actually sounded like my spare tire was jumping around. The sound was deceptive, sounded like it was coming from back but it was only when right front tire went over speed bump. I need to replace engine mount but since you have to replace all 3 if you are gonna do it, i need to wait to get the cash.
Chapter Leader (NY/NJ)
Look at the motor mounts first... Get somebody you trust, open hood, put car in drive, pull the ebrake and press brakes as well and have them give it blips on the gas. See if the motor wants to jump at you. Small blips. Have them test your brakes first b4 you get ran over jr LMAO. If the motor has alot more play, its motor mounts. Mine was completely broken but you couldn't tell by just looking at it.
that ONE RED tl
Being an Acha Bacha in
My dealership just wants to replace front and side. They do not want to do the rear cuz they don't think its needed. I told them that all 3 should be done at the same time cuz another mechanic of mine told me that all of them are gone. Trying to argue my way with them.
Is yours covered under warranty? If not how much they want to get it fixed?
I'm getting a similar sound in mine in the front right corner. Mine happens when I put the car in reverse or drive and hit the gas slightly. It's like a metal to metal clunking or clinking sound. Are my motor mounts suspect also?
Sometimes I noticed a little noise on the front right too, but I thought it may be air pockets in the heater core that are getting circulated around. And come to think of it, I do have a very slight smell of radiator fluid after I park in my garage. But its very little and I don't hear or see anything leaking.. So I don't have a clue what the noise is. But it does not sound like metal clinking or clanking or clunking.. =) It sounds quieter and more subtile. more insulated.
While the car is still, if you bounce the car on the the right front, like over and over, can you hear it make any noise? If so, I doubt it is motor mounts.
Any updates for anyone... I haven't got the problem diagnosed yet. But recently on cold starts, the engine is rumbling more, and when it warms up it stops. Still getting the clunk sound when going over bumps. Are these def indications of bad mounts? I really dont want to keep driving around to long like this, its been like two months already. Has anyone driven post two months with bad mounts?
I dont know how long I have been driving with mine, but I have 74K miles on mine. If you have an auto have someone get in the drivers seat push down on the brake (all the way down) and tap the gas to see how much the mounts flex. There is one mount that you can see easily on the passenger side and one in the center of the engine, just behind the radiator. The others I read are harder to see, but people have suggested replacing them all.
got a free multi inspection from Acura, they claim that i have the left and front motor mounts and the rear and front trans mount done. They are charging $700 for engine and $500 for trans.. Ive decided to buy the innovative mounts for $300 because the dealer is obviously a rip off.
why cant honda make motor mounts last longer?
you sound like me. 05 with 59.5k miles.
So will this fix your clunking sounds?
How hard is it to change motor mounts? Lift the engine with a jack, remove and replace? no? 700 sounds about double what it should cost. Just in my own estimation. I mean, timing belt r&r is internal engine and cramped spaces to work.. So it seems motor mounts would be easier access, and all external engine work..and cheaper. But oh well.. what ya gunna do right?
Head a da Family
Changing the mounts will stop the engine from bouncing around and will reduce engine vibrations. Its an easy DIY if you know about cars, I however will have a friend of mine help me install.
Head a da Family
Just my
I thought 700 for the engine and 500 for Trans was Installed.. Wow. you must be loaded. hehe
btw, I would be careful about buying harder or more firm motor mounts. Because if those motor mounts are more ridged, then it might transfer more noise and vibrations to the frame.. so you will feel and hear it.
