climate info and clock has no lights
Old Jan 10, 2017 | 03:21 PM
sr69's Avatar
5th Gear
hi guys im having a problem with the climate information and clock on my 06 base, basically it started a few months ago when i pulled up in my driveway and seen a light white smoke coming from the steering wheel like right between the cluster and wheel and it smelled like burnt wire and plastic so i turned off the car and disconnected the battery as fast a possible and waited and when i reconnected the battery it was fine with no smoke and started up like normal but i looked at my clock and it wasnt on and neither was my climate info, every thing works on climate control like buttons and lights on the side but its black on both screens until i put a light on it and then i can see everything, the weird thing is when i turn the key to start then car then clock lights up fine but not the climate info until i let go of the key, also i stripped the climate control part to take a look and i notice that when i flick the key forward the climate info lights flick on for a split second and goes back black, so all in all i have stripped the steering column and see nothing wrong and climate control, i have no idea what to look for so i would like to hear from you guys if you can help me out
ps: i have the blue and white light climate info and clock not the black and white 1
Old Jan 10, 2017 | 03:23 PM
pics?
Did you buy this car second hand and someone went and installed LED lights in there? Something seems to have shorted behind there.
Old Jan 10, 2017 | 03:29 PM
sr69's Avatar
5th Gear
hi, yes i bought it used and im pretty sure no one has gone in there cause when i took it apart everything was in place and all clean
Old Jan 10, 2017 | 03:30 PM
sr69's Avatar
5th Gear
sorry no pics at the moment but ill post as soon as i could, its snowing like a b#%ch out here in toronto
Old Jan 10, 2017 | 04:07 PM
WDPanda's Avatar
You may need a new climate control. They're not expensive and you can get one from a part out or kijiji.
Old Jan 10, 2017 | 04:12 PM
sr69's Avatar
5th Gear
i already did, that was the first thing i tried, i bought a used tested climate and clock from some one on kijiji and still does the same thing
Old Jan 11, 2017 | 05:14 PM
sr69's Avatar
5th Gear
im starting to think its the ignition cause i pulled the ecu fuse and held the key in start and everything was lighting up until i let go of the key
