Clicking sound when I press brake pedal?
I'll check tomorrow sounds odd though as it just started happening. Never heard the noise before. It's more of a "click" "click" "click" then is gone when I come to a complete stop. The clicking noise is annoying me lol.Anyone else with an idea ? I'm guessing its the brake pedal switch? Anyone with a part number ? Thanks.
MMkay.
Now if it's a constant clicking while you're holding the pedal down, i'd look elsewhere.
Yeah it's more of a constant clicking and stops when I come to a complete stop. I found this thread it's kind of old though lol. https://acurazine.com/forums/3g-tl-2004-2008-93/brake-pedal-clicking-sound-550569/
MMkay.
So the sound is outside of the vehicle?
It could just be a loose brake pad shim that unhooked it self and is tapping against the caliper. Check your pads & report back.
edit: about your 3rd brake light:are you sure it's out and not just dim? mine had the same problem intermittenly. Hard to tell in broad daylight though. Replace your switch (see my previous post). its less than $20.
takin care of Business in
Received 4,732 Likes
do you see the ABS light?
usually the ABS module produces clicking noise
does it happen at high speeds or any speed?
light braking or heavy braking?
check your caliper bolts....check the caliper pistons...check the fluid level...
also check the condition of the brake lines, does the brake pedal feel soft?
any leaks?
any leaks?
mada51589
05-03-2022 08:54 PM
