Cleared headlights with parking lights/turn signals
So I finally had the courage to clear my headlights! It wasn't too bad except resealing them was not easy and requires a lot of patience.
Everything went well except two things:
1)Before I cleared my headlights the parking light on the right side did not used to turn on when I turned my lights on, but the turn signal worked fine. Now neither the turn signal nor the parking lights work. Could it be the wiring? the bulb?
2)I did some research and supposedly ordered bulbs that light up white and were supposed to be bright. As I said earlier the right side isn't working and the left is not too bright at all and can be hardly seen during day time. Anybody recommend any good bulbs that look nice and still serve their function? Also, how do I change the parking lights without opening up the entire headlight?
Thanks!!
Thanks!!
takin care of Business in
Received 4,732 Likes
^^^ just switch the right and left to see if the bulb is bad
^^^ good catch fulani !!!! check that too !!!
09-17-2015 09:01 PM
Greengecko
09-16-2015 08:19 PM
