CIgar lighter
Old Apr 1, 2008 | 08:19 AM
clavodulce16's Avatar
[PA] NBP-TL
CIgar lighter
Hey `all,
For some reason my cigarette ligther is not work no more. I think a fuse my went bad. Funny part of it all i have no idea where to find the fuse box for the cigarrete lighter.
ps. I don't smoke, just need it to connect my gps lol
Old Apr 1, 2008 | 09:41 PM
Will Y.'s Avatar
Registered but harmless
Cigarette lighter?
I've got two power plugs- one in the lowest front console compartment under the radio/Navi and the other in the lower armrest compartment- but no lighter.
I don't know where the TL's fuse boxes are, but i think one is near the hood release handle above the driver's footwell and the other is in the engine compartment. Try a search for "fuse replacement" - that should pull up some threads with photos too.
Old Apr 1, 2008 | 10:07 PM
Fulani has a TL's Avatar
The fuse box is located on the driver side kick panel, there is a cover that you slide back and forth to reveal the fuses. Look on the inside of the cover and it will have a diagram, and should be able to figure out which one it is. its an ACC fuse I know that, but which number I dont recall
Old Apr 1, 2008 | 10:20 PM
subbuzz's Avatar
07 tl-s in
I do smoke
How do you install the oem lighter without ripping apart the dash? (I thought it was just a plug-in but it's the whole socket)
Old Apr 2, 2008 | 08:38 PM
bforbrian's Avatar
this won't help you at all but
the acura cigarette lighter and the door visors are the greatest gifts you can give to a TL smoker.
Old Apr 2, 2008 | 08:57 PM
csmeance's Avatar
Its very simple, removal of about 10 screws and a few clips, should take about 20 minutes to take apart, 5 minutes to install, then another 15 to put back together.
Old Apr 2, 2008 | 10:28 PM
redondored's Avatar
2005 TL 5AT W/ NAVI
here a link to the instructions. http://www.handa-accessories.com/tl/08U96.pdf
Old Apr 2, 2008 | 11:08 PM
subbuzz's Avatar
07 tl-s in
THANK YOU!!!!!!
funkbro2
Nov 17, 2015 10:23 PM
Rob144
Sep 21, 2015 08:18 AM
Sep 14, 2015 10:09 PM
kuzdu
Sep 10, 2015 08:42 PM
