Check gas cap message
Old Sep 10, 2014 | 12:49 PM
nikolepaige's Avatar
6th Gear
I know... sounds retarded, but I was getting purge vap valve check engine code so I replaced that and the engine light never came back on so a few weeks after I started getting check gas cap message so I bought a new gas cap and it went away for almost 2 weeks and now it's back! And it's not bc I'm not screwing it on enough. Help please
Old Sep 10, 2014 | 02:53 PM
Jesstzn's Avatar
Do a search ... Its not the gas cap but it is a simple $80 fix and 5 min.
Old Sep 10, 2014 | 03:56 PM
pbook4g5's Avatar
Yeah he said in the first sentence that he already did that fix.
OP, I wonder if the part you replaced is bad? That's typically the culprit with that message.
Maybe you have a hole in your fuel filler neck?
Old Sep 10, 2014 | 04:11 PM
Jesstzn's Avatar
Ops . Sorry.
Old Sep 10, 2014 | 04:14 PM
ds03's Avatar
So you already replaced the purge valve? That is usually the culprit.
Old Sep 11, 2014 | 12:36 AM
6th Gear
She* hehe
How would I know if it's a bad part? Buy another and see if it fixes the problem? Yeah I have no idea, I'm trying not to take it to acura, my brother is a mechanic for Lexus and he did the fix but if nothing else I guess I'll take it to the dealership. Thank you
Old Sep 11, 2014 | 12:38 AM
6th Gear
Yep that's the first thing I replaced with the check engine light now it's not the engine light on it's coming up on the little screen on the bottom right.
Old Sep 11, 2014 | 08:49 AM
ds03's Avatar
Interesting. Normally the valve needs replaced when the gas cap light comes on, not the check engine light. If you had the CEL come on first I would think that indicates something more is wrong than just the valve (or instead of the valve). More investigation is needed, but not sure what advice to offer other than getting someone qualified to check it out.
Old Oct 15, 2014 | 04:01 PM
mike421's Avatar
So I have the same problem. I already replaced the gas cap and PCV and the tighten gas cap light still comes on. I'm going to try replacing the fuel filler neck next. Anybody know the part number for the fuel filler neck ans how hard is it to replace.
01CLOwner
Oct 9, 2015 01:07 PM
sockr1
Oct 1, 2015 01:31 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
BigJilm
Sep 21, 2015 08:32 PM
GhostTL09
Sep 19, 2015 01:57 PM
