"Check fuel cap"...simple fix?
Old Jun 1, 2010 | 12:15 PM
sevank21's Avatar
AKA WalkerUA6
LOL. Sorry if this is a simple fix, but but my dash indicator says to check fuel cap. I opend it and closed it tightly but the indicator still remains....help?
Old Jun 1, 2010 | 12:20 PM
nfnsquared's Avatar
3 clicks? Check the other threads...seems to take a couple of days to clear....
Old Jun 1, 2010 | 12:36 PM
HEAVY_RL's Avatar
Keep driving it will go off...
Old Jun 1, 2010 | 06:11 PM
sevank21's Avatar
AKA WalkerUA6
Ok thanx. Well see
Old Jun 2, 2010 | 07:54 AM
cfv22's Avatar
You need to read older posts or use the search function. This issue has been covered here many times. Your problem is the PVC valve. You need to change it or have dealer do it for you. You will continue to get this error until you do so...changed mine and never saw the error again...
Old Aug 4, 2010 | 01:50 PM
VQPower37's Avatar
is the pvc valve considered part of the emmisions system?
Old Aug 4, 2010 | 02:37 PM
TPROX's Avatar
Evap canister.......
Just picked my car up from Radley's of Falls Church yesterday.......
Among other warranty things fixed.
There is an Acura TSB on this and covered under the warranty..........
Or you can just watch it cycle on and off, as it will........
Old Aug 4, 2010 | 10:30 PM
240sx acura tech's Avatar
acura master tech
its the pcs valve. or purge control silinod. its on the intake plentum. behind the throttle.
Old Feb 18, 2011 | 11:32 PM
jimmyl's Avatar
Plastic schmastic
Item #1 on this link I'm guessing?
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Is that the "sensor" many of these "fuel cap" threads point to?
{Been searching}
Sounds more like this solenoid would fail causing a sensor somewhere to become angry with what it is reading, but I haven't found a monitoring sensor yet in my searches.
Item #12 is all I've found so far, but temp sensor doesn't seem to have anything to do with fuel pressure/tank pressure.
17382-SDA-A00 Maybe??? can't find pic. says pressure sensor, but may be for tires for all I know....
Lots of editing! Item 20 maybe???
http://www.thehondapartsstore.com/he...All&vinsrch=no
Old Apr 29, 2011 | 10:35 PM
steve5chang's Avatar
4th Gear
I had the same problem, got it fix at the Acura dealership..simple fix covered under warranty.
Old Apr 29, 2011 | 11:05 PM
abrieluno's Avatar
Chapter Leader (Eastern Canada)
which one causes the problem? other members say PVC valve somebody else says PCS valve any difference on this?
Old May 12, 2011 | 09:16 AM
miltontls's Avatar
6th Gear
I HAVE THE SAME PROBLEM ON MY 08 TL-S, I HAVE 55K, IS THIS COVERED UNDER WARRENTY??? IF NOT HOW MUCH TO FIX, I KNOW THERE ALL DIFFRENT PRICES BUT HOW MUCH DID U GUYS PAY? CAN ANY COPY AND PASTE THE TSB FOR THIS TIGHEN FUEL CAP, BECAUSE EVERY PAGE I GO TO IT SAYS ERROR... THANK U IN ADVANCED
Old May 12, 2011 | 06:27 PM
dzionny_dzionassi's Avatar
when i called acura with the same problem and explained my problem and explained what part i would need to change, they said that i ran out of warranty. that time i had 50k on my 2007 acura TL-S. I hate dealers... bought the part for 82$ i changed by my self.
Old May 12, 2011 | 07:57 PM
VEIVIOI's Avatar
6th Gear
98% of the time it is the fuel cap itself not sealing. I would start with replacing the cap since it is more than likely the cheapest thing to try....
Old May 12, 2011 | 08:16 PM
i disagree 98% it is pvc valve, not the cap, especially if you have TL-S...
Old May 14, 2011 | 08:34 PM
Queen Crimson's Avatar
Already replaced the gas cap - still get the message - sometimes 2-3 times per tank. I mean how hard is it to tighten a gas cap? Naahhhhh...not the problem. Going to the dealer and have them replace the purge control valve on warranty.
This site is a GREAT resource.
Old May 15, 2011 | 02:11 PM
jdmej1's Avatar
they're are three major parts...purge valve..gas cap or gas tank filler tube...but if u pump gas and when the pumps stops and u just give it a fuel clicks more and more..thus, will eventually produce more gas flumes and most of the time make the purge valve stick...soo go underneath your hood and find the purge valve and give the purge valve a few taps with a screwdriver or anything to bang it and go drive the vehicle and it should go awayy..90% of the time is the purge valve
Old May 29, 2011 | 07:34 PM
Talking Dealer replaces purge control valve as goodwill
So even though I was over 50K (55K+) miles and I go to an independent for service, the dealer replaced the purge control valve as goodwill. They tried to weasel out of it, but I said I had the documentation to prove that the problem started before 50K and I had already tried to fix the issue by buying a new gas cap. I even used the 'this is a known issue out of the forums' and they said, 'oh yeah, it's the solenoid'. Really.
This site is an excellent resource!
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
NBP_BALLER
Sep 23, 2015 08:18 PM
Gary Matthews
2G CL Problems & Fixes
Sep 11, 2015 01:21 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
NSolace
Sep 3, 2015 08:14 PM
