Check Fuel Cap Message???
Old Sep 30, 2008 | 09:20 PM
henrychan718's Avatar
So today, I went to the gas station and filled my car up. After driving for another 10 minutes or so back to my home, I noticed a message was being displayed saying my fuel cap was not closed. I've checked and it seems to be fine and I even twisted it some more.
Can someone tell me how I can fix this problem?
Old Sep 30, 2008 | 11:07 PM
Houston's Avatar
Here I come!
This is straight from the owner's manual:
The CHECK FUEL CAP message should go off after tightening the fuel cap, turning the ignition switch off and on, then driving over 30 mph(48 km/h) for at least 45 seconds. Due to different driving conditions, it may take a few driving trips to make the message go off. If a loose or missing fuel cap was not the cause of the CHECK FUEL CAP message coming on, the message will turn off and the malfunction indicator lamp will come on. If this happens, have your vehicle checked by a dealer as soon as possible
Old Sep 30, 2008 | 11:57 PM
01tl4tl's Avatar
nice job H! you are fast becoming a major asset to the board!
thank you!!
There have been poblems from a loose filler pipe seal to bad gas caps
Make sure you tighten it to 3 clicks
10 clicks is not required and does not actually tighten the cap any more!!
The first click is the tight indicator- the next 2 ensure you really did get it on tight
The TL fuel system needs an airtight setup from the airfilter box at one end and the gas cap at the other
If the book method doesnt solve it- call for an appt with the dealer
Call acura and make a file complaint, 1-800-382-2238 x5 ask for a recall check on your VIN number too- register with them as the owner
gen 3 needs those power steering hoses replaced!!!
some danger of underhood fire~
and some cars get a new wiper motor-- as it quits without warning---nice - get it fixed for winter
Old Oct 1, 2008 | 01:09 AM
hoangtran9's Avatar
you should bring to the dealer to let them know and they might replace for you a new sensor. It happend to my car and they replaced for free if your car under warranty.
Old Oct 1, 2008 | 12:25 PM
Houston's Avatar
Here I come!
thank you!!
As you can see, I'm catching up to your posts.
Old Oct 1, 2008 | 03:08 PM
01tl4tl's Avatar
you can have the whole amount if it means I dont have to answer the same questions and remind everyone of the owner book and acura reg and .....
my free time for azine has cut down --trying to have a life~
01CLOwner
Oct 9, 2015 01:07 PM
sockr1
Oct 1, 2015 01:31 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
GhostTL09
Sep 19, 2015 01:57 PM
NSolace
Sep 3, 2015 08:14 PM
