Changed fogs to HID, question though.
Old May 28, 2009 | 11:20 PM
monkeyquach's Avatar
There is a TL & GL in
I bought the ddm tuning raptor hid kit for my fogs.
Today i installed that as well as an AEM v2 intake and i painted some parts of my grill.
Is there a way to upload pictures directly on to AZ or they have to be hosted somewhere else.
anyways my real question is the HID's blow the 10A fuse but work fine on 15A is it safe to upgrade the fuse like that?
Old May 29, 2009 | 03:19 PM
dudechewy's Avatar
DuDeChEwY
you will have to have another website host the pix first.....go to flickr.com....its a free.....just host em off there...
Old May 29, 2009 | 03:40 PM
msala524's Avatar
08 TL-S NBP
you need to read the instructions and use the fuse they recommend, if you use a higher fuse you have a chance of messing up the warranty. Make sure everything is grounded. You will also need to install a relay to make sure they work right. That might be your problem, trying installing a relay
Old May 29, 2009 | 03:41 PM
95oRANGEcRUSH's Avatar
KBPftmfw
I had the same problem. I have been using a 15a fuse for over 4 months now with no issues. A relay is definitely best and recommended, though.
Old May 29, 2009 | 03:51 PM
sixsixfour's Avatar
from what I recall, you want to use the fuse specified. and typically, it is the lowest that you can get away with. you dont necessarily want to switch to a higher fuse than what the wiring can support - for example, you dont want the fuse to remain good while the rest of the electircal components are already fried.
Old May 29, 2009 | 11:50 PM
EvoToTL's Avatar
Former Street Racer
so if i upgrade my fogs to a 35watt hid kit i still need to change the fuse to 15a or use a relay?
Old May 30, 2009 | 05:49 AM
msala524's Avatar
08 TL-S NBP
You should definitly use a relay, and I would use the fuse that came with the kit. I wouldn't go higher or lower.
tman570
Jun 11, 2019 07:56 AM
pozebly
Sep 23, 2015 07:30 AM
MyGuti
Sep 12, 2015 06:52 PM
Aleax
Sep 11, 2015 11:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
