Center console Drivers Side vent not working..
Did anybody else ever have this problem? The drivers side vent above nav screen does not have any air flow the pass one next to it does though any suggestions? I know they are seperated due to the dual climate control so i don't know if a damper is stuck or what. Where would damper be?
Mine moves some air, but not nearly as much as the pass side. If I block off the far left vent on the driver's side, it blows quite a bit more than the pass side. I mentioned it once to the service writers and they stated it is a fairly common issue. However since I am out of warranty it wasn't worth pursuing.
This won't help you but I thought I had the same issue and it turned out to be a closed passenger right vent. Made it seem like only the passenger center was blowing.
rockyboy
08-04-2024 10:35 AM
marcelft
07-10-2018 06:17 PM
sockr1
10-01-2015 01:31 AM
