Cel on code p0108 how do i fix
Old Aug 4, 2009 | 06:02 PM
jnice's Avatar
2damndvs4uhaters
As i was on manual mode at about 6500 rpm my cel light started flashing then stood on i got code p0108 map boro circuit high input and code p0301,p0305 cyl 1 and 5 misfire aswell as p0300 can anyone tell me whats wrong and what i need to replace
Old Aug 4, 2009 | 07:55 PM
mlassek's Avatar
P0108- MAP sensor circuit high voltage
check the wires and connection on the sensor that sits right on top of your trottle body(the MAP sensor). if all looks good, replace the MAP sensor. clear the dtc's
the misfire codes are a byproduct of the P0108
Old Aug 5, 2009 | 05:31 AM
jnice's Avatar
2damndvs4uhaters
The map sensor appears to look in like new condition but im gonna change it anyway can i just buy one from autozone and has anyone else had this happen to them ive only had my tl for 5 months and have done so much to it i love the car but dont wanna deal with bullshit if im gonna be trouble shooting i might just sell it and buy a 2007 type s 6 speed i buy my cars cash never finance but ive seen them going for $22,000 here in n.y anyway hope i can fix it so i can keep it for atleast another 6 months i have 2 many toys already and dont want to hear the wife tell me i have A.d.d
Old Aug 5, 2009 | 11:16 AM
bhelsdon's Avatar
FYI, the sensor maybe telling the truth. If you have a valve problem it would cause pressure in the manifold versis vacuum. The sensor is looking for vacuum. How is the car running? You also said something about misfire codes. You could have over revved it and bent a couple of intake valves.
Old Aug 5, 2009 | 02:52 PM
jnice's Avatar
2damndvs4uhaters
Wow never thought about that i guess it runs fine i cleared the code 2 days ago and it hasnt turned back on i took it for a drive and shifted threw the gears and it didnt come back on but i guess ill have a mechanic check if so do i port and polish it while it is of has anyone p&p thier head
Old Aug 7, 2009 | 08:04 AM
jnice's Avatar
2damndvs4uhaters
Has anyone else delt with the map sensor going bad?
Old Aug 8, 2009 | 11:20 AM
StickShiftTL's Avatar
check all the hoses that connected to the intake !
Old Oct 11, 2015 | 05:49 AM
Sorin Busi's Avatar
Mine has a P0108 and P0172. I have checked for air intake leaks, cleaned the EGR, changed spark-plugs, verified coils. Even went on swapping the purge solenoid and the MAP sensor from my other Acura with this one but still no lock.
Car is shaking when idle and CEL is on.
Ideas, comments...
Thank you
Yikes
May 3, 2021 04:29 PM
SidhuSaaB
May 30, 2020 12:40 AM
NJALLDAY57
Oct 13, 2015 08:25 AM
ibGTV
Sep 28, 2015 03:40 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
