Catalytic converter malfunction???
I was just wondering if anyone could tell me what the cause for a bad catalytic converter could be. I have a 2006 tl with 24000 miles and this is the second time the dealership is replacing it. I thought they usually last the duration of the car. Should i address this with the dealership when I pick the car up? Any response or help would be appreciated.
do you drive it hard and fast and get bad smells from under the car- that will be one cause
Otherwise keep your mouth shut- the cat has a 80k mile warranty on it and they are not cheap- nearly a grand iirc
Perhaps acura got a bad batch of ones for the assembly line, and used the same ones on replacements
Kind of like the gen2 transmission saga
