Cassette Player Not Working!!
Old Jun 10, 2013 | 10:18 PM
  #41
Jenluv186's Avatar
Certified Gangster
I'm having the same issue. I'm scared to stick a screwdriver in there. I tried it once and it didn't budge. I don't want to replace stereo bc I like my steering controls and don't wanna deal with all that bs. Can you put it in girl terms please?
Old Feb 26, 2014 | 03:59 AM
  #42
zenki972's Avatar
Just have to play with it some with a flat head screw driver.This happen to my daily 04 tl and had to get the tape adapter out using that method.GOOD LUCK
Old Mar 8, 2014 | 07:45 PM
  #43
nokiaboy808's Avatar
06 6spd TL BAGGED
Just did the trick using a flathead screwdriver and pushing the tape to the left (with a decent amount of pressure) and it started reading the tape again! Just remember to use a decent amount of pressure when pushing the tape to the left because at first i never really use much pressure thinking i will break it if i did but that did shit.
Old Mar 17, 2014 | 07:28 PM
  #44
curtis_k's Avatar
7th Gear
my problem is different my take players still works but my cd sounds like its stuck in a cycle and when I try to select CD mode it changes back to fm any ideas
Old Jul 14, 2014 | 04:45 PM
  #45
williecoyote's Avatar
3rd Gear
Thanks Grinder, I owe you a beer too!
Old Jul 2, 2015 | 02:17 PM
  #46
Tundra9024's Avatar
Lots of great suggestions.. But..
So I am having the same problem. However, my battery died in my vehicle and after I jump started it the cassette was rejected. Now I understand that this is normal for that to happen. However, whenever I answered it back in, it will read for about 5 seconds and make scratching noises and almost as if the gears are moving. Like I can tell it is working, but it won't play. It just goes right back to FM. I tried the screw driver method, its not working. Maybe I need to put a little bit more pressure? Is there any advice for a low price adapter for just simple auxillery connections?
Old Jul 17, 2016 | 11:04 AM
  #47
kishanW's Avatar
yeah, you will have to apply some pressure. I had the same issue and it drained the battery. Next time when i started the car i applied enough pressure the radio had the cassette loading message and clicking eject button worked. The cassette came out
Old Feb 5, 2017 | 12:34 AM
  #48
xaqtiman's Avatar
5th Gear
Whoa, this thread really helped out. Thanks OP and other posters.
My tape adapter got stuck a few weeks ago. The Disc / Tape button would not recognize that the tape is in there and would not go into tape mode. Then my battery died. Not sure if that was a co-incidence.
Jumpstarted the car yet the Disc / tape button didn't recognize that the tape adapter was stuck and would not go into tape mode. After jumpstarting the car took the car to the shop and got a new battery. Tape did not pop out. Still the same problem.
Did a search and found this thread. Used a flat-heat screw driver and removed the tape.
Old Mar 21, 2026 | 10:32 AM
  #49
Ahmety0's Avatar
Help
Hello I just bought a new Acura tl 2002 and I just turned on the radio after putting the code in and I’m having the same troubles as you, did u end up fixing the problem ? If so what did you do ?
snorf
Nov 4, 2019 06:44 AM
acurajj
Sep 19, 2015 03:47 PM
MyBlackBeauty
Canada
Sep 14, 2015 05:28 PM
ivegotthenav
Sep 11, 2015 07:51 PM
Aug 30, 2015 02:39 PM
