Car wouldn't start, then it exploded
Old Mar 6, 2014 | 11:02 AM
  #41
paperboy42190's Avatar
Speechless how an 08 TL has been through so much in 50k miles....luck is definitely not on your side
Not sure what to say but I hope everything starts going better. You're handling this situation very well given the circumstances
Old Mar 6, 2014 | 11:10 AM
  #42
rockstar143's Avatar
George, we getting trolled?
Old Mar 6, 2014 | 11:15 AM
  #43
Old Mar 6, 2014 | 11:51 AM
  #44
LOL...me too. I don't know...new member, very low posts...crazy azz story.
Old Mar 6, 2014 | 12:22 PM
  #45
Majofo's Avatar
Originally Posted by mzilvar
I'm still trying to wrap my mind around how the hell that chunk of metal blew out of the water passage, how did pressure get so high in the cooling lines to blow it out like that or did something blow down from the manifold into it and make it break like that?
There's no coolant running through the manifold or runners, those lines are all separate and it blew out right by the thermostat, not the EGR.
I can't imagine the water pump being in perfect shape, since that thing blew a huge piece of metal out of the water passage.
The other side of the water passage has a connecting pipe that runs underneath the lower intake runners to the side of the block where the belts are and goes into the block on the rear side of the water pump.
If pressure got that high inside of those lines to break that metal like that I would imagine it could've pushed the water pump away from the block as well.
What've you been running for coolant? Just curious, it almost looks like it's been running on water instead of coolant from the color of the spray on your engine cover and the corrosion on the throttle body and water passage.
Looks like the underside of the manifold that broke off
Old Mar 6, 2014 | 04:49 PM
  #46
mzilvar's Avatar
Lol you're right what I thought was a hole is the metal laying on the passage
Old Mar 6, 2014 | 08:13 PM
  #47
I hate cars's Avatar
There's no doubt it was an intake backfire. It's normal to have fire coming from the intake ports during cranking so you have your ignition source. What is hard to understand is how enough fuel built up for that kind of backfire. On another note, this is why a lot of high hp turbo and especially nitrous cars use burst plates on the intake manifold. It's just a bolt in plate (sometimes a PRV) designed to give before the intake manifold or some other part of the car does.
I have a couple ideas in this case but I need to go back and read the old thread.
No one sprayed any kind of starting fluid in it, did they?
I've seen cars blow the supercharger and even the intake manifold clean off the car and the rest of the engine was fine. A severe intake backfire rarely causes engine damage.
One thing to look at, is the cam timing correct or did it jump a tooth or two?
Did this guy possibly hook the coils up wrong? I know this would be hard to do but it would perfectly explain what happened.
Old Mar 7, 2014 | 12:11 AM
  #48
Majofo's Avatar
You ever see a cast aluminum intake manifold explode like this in a NA application IHC? What I think is crazy is the intake manifold volume is pretty decent, there was probably quite a lot of vapor accelerant to cause this reaction
Old Mar 7, 2014 | 02:51 AM
  #49
well he does have pics to back it up, and his posts from his previous threads do sound pretty legit
Old Mar 7, 2014 | 03:02 AM
  #50
mzilvar's Avatar
I think that manifold is a magnesium alloy just like the 4G manifold that's been swapped into the 3G TLs.
I'm pretty sure the 04-06 manifold is aluminum, but the 07-08 is two pieces bolted and held together with some type of liquid gasket. I've had these parts powder coated and they have to be heated up on a hanger for a while first so the magnesium can off-gas so it doesn't create bubbles in the finished product.
The valve covers on the Type-S are also magnesium alloy, I have a set that I had powder coated in my bedroom right now waiting for me to install, they have a MG stamp on the inside of them as well.
Probably why if you've ever seen someone try to paint the valve covers their paint probably didn't stick very well. Once you strip the old paint off, if its taken down to bare metal, the covers need to be blasted or keyed to create a tooth on them and then hit with a non-etching epoxy primer if it's going to be painted, or they can be chemically treated and powder coated.
Old Mar 7, 2014 | 08:24 AM
  #51
Not often. This is probably the worst I've ever seen unless he had a hidden 100 shot lol.
The only thing close to it was when the timing was off. I've seen it blow a turbo apart as well as both mufflers downstream and it bent the throttle plate and blew any vacuum line that wasn't zip tied off. That engine however was running when the cam sensor came loose and turned. This thing would have to be cranked for a while to dump enough fuel and then the wrong series of events and basically the perfect storm for this to happen. I would almost bet the people who did the headgaskets screwed up the timing belt somehow and it jumped time.
I've got another theory that has to do with coolant in the cylinders but it's a little far fetched.
Old Mar 7, 2014 | 09:32 AM
  #52
Either way, crazy story. In to hear about the outcome and diagnosis.
Old Mar 17, 2014 | 07:42 PM
  #53
curtis_k's Avatar
7th Gear
wow that's some work there
Old Mar 17, 2014 | 07:43 PM
  #54
curtis_k's Avatar
7th Gear
but no matter what Hondas and Acura's are family it should not have been an issue for them to check it out
Old Mar 18, 2014 | 12:18 PM
  #55
swoosh's Avatar
takin care of Business in
well now I certainly cant explain how my old valve covers had some paint over spray on them which just wont come off LOL
Old Mar 18, 2014 | 05:46 PM
  #56
mzilvar's Avatar
Overspray is stuck to the old paint
If they're repainted and you take them down to bare metal, however, can definitely run into some problems.
Old Mar 19, 2014 | 11:56 AM
  #57
swoosh's Avatar
that was the old setup, I am running these now
http://www.flickr.com/photos/44051364@N00/9227245140/http://www.flickr.com/photos/44051364@N00/9227245140/ by http://www.flickr.com/people/44051364@N00/, on Flickr
http://www.flickr.com/photos/44051364@N00/9224471313/http://www.flickr.com/photos/44051364@N00/9224471313/ by http://www.flickr.com/people/44051364@N00/, on Flickr
Old Jul 17, 2021 | 07:09 PM
  #58
Smottie Bug's Avatar
3rd Gear
boom
I have a theory that it wasn't fuel explosion but actually a air pressure explosion it doesn't look like it broke right after the water pump my guess is they were redoing gasket or Cooling that's somebody that's a rag inside one of the ports well they were working on it to keep out the dirt but forgot to it out and collected the hoses back up why you said it wanted to start up but it couldn't because it's building up pressure probably start wanted to start beginning morning and then stop let it sit for a while if I want to start again will it build up pressure until it eventually Boom
Old Sep 9, 2021 | 10:37 PM
  #59
David_Pooh's Avatar
Intake manifold blew
Any solution or reason why this happen?.. thanks
Old Sep 12, 2021 | 07:22 AM
  #60
DMZ's Avatar
DMZ
Head a da Family
It means my guys planting a bomb in yaw caa did a lousy job!
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
dlknight
Sep 3, 2015 07:54 PM
