Car transmission problems
So did it drive fine up until you parked it? No reverse either? If the green light is blinking, there's a code stored so reading that code would point you in the right direction. It can be almost anything from internal hard parts breakage, torque converter, an axle, etc. Does it make any noise? Did you check the fluid level?
Zonian22
11-14-2015 01:20 PM
Mike Bertram
09-10-2015 09:27 AM
