Car/steering wheel vibrating
Old Sep 5, 2013 | 01:18 AM
NemoTL-S's Avatar
Hey guys, I have a 07 TLS mt, I couldn't figured it out why my car vibrating from 20-28mph and 65-75mph it doesn't seem like it need to balance. Does anyone has a same problems?
Old Sep 5, 2013 | 04:35 AM
paperboy42190's Avatar
why do you say it doesnt seem like it needs a balance? vibrations in steering wheel at high speeds are almost always balancing issues
Old Sep 5, 2013 | 04:47 AM
TLtrigirl's Avatar
3G TL/2G MDX Owner
could be any number of things:
wheels/tires
axles
LCA compliance bushings
motor mounts
you need to provide more info in order to narrow down the list.
recent install of new tires?
just started happening?
recently hit a pothole?
only happens when accelerating in town from a stop?
only happens at hwy speeds cruising?
the more descriptive you are as to WHEN this vibration occurs the better we can help you figure it out (we aren't all mechanics on here, but many of us have had similar things occur with our vehicles and had them fixed).
if you search, you will find there are a number of existing past threads about this topic.
Old Sep 5, 2013 | 09:35 AM
94eg!'s Avatar
#1 Super Guy!
Step one: Rotate your tires. If it goes away or moves, you know it's a wheel/tire issue. If it doesn't change, then come back here and let us know more.
Old Sep 5, 2013 | 10:21 AM
NemoTL-S's Avatar
It vibrating around 20-28mph I'm positive it not a balance issue
Old Sep 5, 2013 | 10:24 AM
NemoTL-S's Avatar
wheels/tires
axles
motor mounts
Tires at 70% and it has been rotated
It happened months ago
No hitting pothole
It vibrating when accelerating to 20-28 and 65-75
Old Sep 5, 2013 | 10:52 AM
94eg!'s Avatar
#1 Super Guy!
Step 2: Reach under there and check your CV boots (all 4). This is an easy check by laying on the ground and reaching up under the car to either end of the driveshaft. Vibration under acceleration is a typical symptom of worn inner CV joints. If the boots are torn, all the grease gets thrown out of them. Then it's only a matter of time before the 3 spherical roller bearings wear out.
Torn boots: https://www.google.com/search?q=torn...NsOp2QXHnYGwDQ
Typical Honda Tripod style inner CV Joint:
redsox68
Sep 16, 2015 06:18 PM
kuzdu
Sep 10, 2015 08:42 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
Joshoats
Sep 7, 2015 09:00 PM
nishant11
Sep 2, 2015 10:34 AM
