Car pulls to the side after tire rotation
I have 32K on original Michelin tires, the fronts worn on the sides, and rear had plenty of thread. After rotating the tires a couple of weekends ago (merely put fronts to back, and vice versa), my car started pulling to the side, and I am getting some sort of vibration from the right front. Is there an explanation for this?
It could be just as simple as the wheel balance..maybe the weight flew off, or it could a bad rim. How is the tire itself?
the tire is in perfect condition, with about 70% tread left- it was prev mounted in the rear
about six months ago, the dealer did a 3rd gear tranny fix, and tech had to do an alignment after taking out the tranny. The car did not pull to the side after that...How can rotating the tires for 1st time at 30k mi cause the car to start pulling to the side?
I have no clue, it really shouldn't pull at all.. is the wheel balance weight there? Is the rim sitting in properly? I know these are all common sense things, but you never know, we all make little mistakes. Just recheck.
I don't see how rotating tires can throw car off it's alignment.
NTMD8
I had the same problem when i changed my rims on my TL, after reading a bit online. It is possible that this can be due to uneven tire wear as well, or manufacturer tire defect. After posting in the problems/fixes review and reading the resposnes there I decided to check tire rack as well.
http://www.tirerack.com/tires/tirete....jsp?techid=12
its most likely a tire pull, i have seen this happen many times after a tire rotation...just cross rotate the front tires and this usually straightens it out or just causes it to pull the opposite way
Zonian22
09-02-2015 08:19 AM
