Car pulling hard to the left
i recently got a used tire on ebay to replace one that had developed a bubble. same exact tire since my tires were 2 years old. tread depth was similar to others. i measured 7/32 for used tire and 8/32 for other 3. anyway i had it put in and balanced and did a 4 wheel alignment. car has always drifted to the left since i bought it used but now it pulls hard to the left. very annoying and thought maybe its the difference in tread depth or maybe they messed up the job although they did the alignment perfect in the past. was wondering what thoughts the masses would have on this dilemma and possible fixes.
switch your front tires L - R and see if it changes, I am assuming the new/used tire is on the front. put it in the rear and see what happens you need to experiment
same issue
Heyy i had the same exact issue... I had hit a pothole and replaced the front left tire. Before i had any time i had a replacement that my tire guy gave me until i could warranty the tire. SO i rotated the front tires to the back. Anyway long story short when i rotated, the car was pulling hardcore to the right. So i had acura do an alignment. They said everything was fine. Still the car pulled when i hit the gas. So after process of elimination. and checking to make sure the rim or any other rims were balanced and not bent, the last thing was that i could have a defective tire. If a rim was bent the car would wobble . So i brought it to mavis where i got the tires and they replaced the front tire on the left after i jumped through all of their hoops and was miserable. But that was the problem the tire was defective. This is rare, but worth looking into. The treads were fine and there was nothing visible that showed a tread skip... so you can check that as well!!
-------Tim-------
Oakes
Wash & Wax
10-12-2015 11:17 AM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
