Car pulling to 1 side after rim install
Old Apr 29, 2009 | 09:31 PM
jimsta's Avatar
NTMD8
Hey,
So I recently put on a used set of rims I had purchased, piaa super rozzas, 235/18/40, rim width is 8'. I had all 4 wheels balanced prior to car install.
Now after installation, i noticed that the car pulls to 1 side alot, its not slight and is quite strong. I didn't think an alignment would be needed if I went from stock to 18s. Is there something else besides alignment that may be causing this?
Old Apr 29, 2009 | 11:10 PM
D'sNBP's Avatar
hates potatoville
You should get a wheel alignment. Someone correct me if I'm wrong but it sounds like maybe one of your wheels that was balanced should be placed in the back instead of the front driving wheels. I had this problem when I was in Japan with an integra. Try switching them to the rear and then drive it. If it still pulls to either side then you should an alignment.
Old Apr 30, 2009 | 12:38 AM
dechlin's Avatar
try swapping the two front tires (side to side) if theyre not rotational. if it pulls to the other side its a radial pull and its in the tires
Old Apr 30, 2009 | 09:50 AM
jimsta's Avatar
NTMD8
I'll try swapping the back and front tires on 1 side to see if that helps, but my tires are radial (Toyo proxes 4), so I won't be able to switch them from 1 side to the other.
rseb4agze
May 3, 2016 07:41 AM
nanos
Nov 12, 2015 08:41 PM
lland
Oct 4, 2015 04:47 PM
Phambam12
Sep 6, 2015 06:57 PM
devinv1994
Sep 3, 2015 01:40 AM
