Cannot Find Parts in Parts Catalog
Looking for help finding some parts that are missing on my car.
I have taken pictures of a couple of them.
Below is on the left rear of the car. I am not 100% sure what line that is, so that may be part of my issue in finding the clip. Clip was zip tied before I got the car, I only noticed when doing my coilovers.
This is one of the front door bumper grommets. I've now ordered the wrong part twice. The "grommet" for the front door on the catalog is the piece the screw goes into. Not a total waste of money because on the front driver door, the screw had frozen, so I ended up replacing a broken piece today. Passenger front door is missing the rubber piece over the screw.
BONUS - Just realized a piece of my hair was in the picture. Also how dirty my door panel really is. Previous owner was a smoker. 95% of smell is gone, but stuff like this remains.
Other item:
One of the grommets for the plastic covers in the engine bay is missing, specifically the one for the rear of the engine cover.
The bolt that holds the washer fluid reservoir is also missing. It causes the plastic cover on top to not fit properly. Probably doesn't help one of the pegs is broken either.
Sorry for the picture sizes, it would not let me add via an Imgur link, so I pulled right from my PC.
Appreciate any help!
Trying to get this car as pristine as possible.
Other item:
https://www.acuraoemparts.com/auto-p...nes-vsa-1-scat
Maybe part #28 ^ ?
https://www.acuraoemparts.com/auto-p...or-lining-scat
Maybe part #16 ^ ?
https://www.acuraoemparts.com/auto-p...nifold-06-scat
I'm confident part #11 is the engine cover grommet you need ^.
https://www.acuraoemparts.com/auto-p...-washer-1-scat
Part #11 should be the missing bolt/s you need to secure the windshield wiper reservoir ^.
Maybe part #28 ^ ?
Maybe part #16 ^ ?
NoTLoud (02-26-2017)
Maybe part #28 ^ ?
I'm not sure the clip is for a brake line. Not sure what that line is. Still familiarizing myself.
Maybe part #16 ^ ?
Unfortunately, #16 is the wrong part I ordered. The name is pretty mis-leading.
Ah, I didn't think to look at the manifold diagram! Thanks!
Looks like it, I will order and see!
Maybe part #28 ^ ?
Maybe part #16 ^ ?
The first picture looks like the wheel speed sensor line.
https://www.acuraoemparts.com/auto-p...lower-arm-scat
#23 and 24?
#23 and 24?
#23 and 24?
#23 and 24?
#23 and 24?
#23 and 24?
I only need the bolt the holds the reservoir in place. My guess is the dealership lost/forgot it when the did the timing belt or side engine mount prior to me purchasing the car.
No worries, appreciate the offer though!
I'll have to check out what you're selling. I ruined the aluminum trim in my center console thinking they were only $90 each for some reason, turns out they're $270 a piece.
I am pretty sure it is the bolt that is linked above. As far as I can picture in my head, it's the bolt that is near the PS reservoir.
IRT Wheel sensor wire: https://www.google.com/search?q=5747...d-GfkHxiBiDSM:
Pictures sure look like it's included, but this is from dismantlers. It's still just a zip tie from OEM so don't bother..
these are all the same part numbers:
90102-SB0-000, 90126-SK7-000, 90126-SK7-003, 90127-SA0-000, 90127-SA0-010, 93415-06014-08, 93415-06016-08, 93485-06016-07, 93485-06016-08, 93495-06016-08
look like 6mm bolt with 16 thread pitch? i believe..
I do need to get a new zip tie on, that one doesn't really fit on very well because I broke the top off the clip. It was previously broken, but I did break it more.
For washer fluid reservoir, I'm going to go with the bolt alexb linked.
Anyone have any ideas on the rubber door damper?
Also, my glove box damper doesn't really seem to work, I wasn't sure which of the two that were listed as dampers were the correct one. It looked like 77530-SDA-A02.
But it's not perfect!
