a/c compressor clutch
Old Jul 7, 2017 | 01:27 PM
scootspop's Avatar
i have a 05 acura tl and the a/c compressor clutch wont engage
Old Jul 7, 2017 | 02:43 PM
Ron A's Avatar
Administrator
Welcome to the forums.
This thread has been moved from the 1G RDX DIY & FAQ Forum to the car specific forum applicable to your vehicle.
Old Jul 7, 2017 | 03:43 PM
DogP's Avatar
I don't know if there are any common AC compressor/clutch problems on the TL, but generally when I've had an AC clutch that wouldn't engage, it was either low on freon (leak somewhere) causing the pressure switch to disable the compressor, a bad compressor clutch coil, or an electrical issue (blown fuse or bad connector). Freon leak would definitely be my first guess, and it's easy to check with a pressure gauge. With all the old cars I've owned, I've come across lots of AC problems. :-P
Pat
Old Jul 7, 2017 | 06:02 PM
nfnsquared's Avatar
Also might be a relay. OP, do a search, lot of discussion on AC clutch issues.
Old Jul 7, 2017 | 06:41 PM
Adobeman's Avatar
The DVD-A Script Guy
Like nfnsquared said. Search. More than enough discussion on this already. IMO very common problem as Honda/Acura cars get older. Here's a google search directed back at Acurazine that will have many links.
https://www.google.com/search?q=site...lutch+adobeman
TL;DR - If your fans come on when you switch on AC it's not a charge issue and probably A/C clutch/coil, relay or wiring in that order of likelihood.
AColli3r
Jul 24, 2025 09:45 AM
EE4Life
3G MDX (2014-2020)
May 2, 2025 07:39 AM
EE4Life
3G MDX (2014-2020)
May 2, 2025 07:32 AM
NCTL05
Dec 6, 2016 09:52 PM
JRhodes88
Nov 12, 2016 05:31 PM
