A/C cold air goes of and on
Old Jul 4, 2017 | 02:45 PM
Glorygang600's Avatar
Just had a specialist vacuum and put in freon but for some odd reason it seems like my cold is goes off and on at will. Any suggestions or theories at to what the problem is my condenser appears to be working just fine
Old Jul 4, 2017 | 02:49 PM
Check your relays
Old Jul 4, 2017 | 03:31 PM
Check your relays
I will most likely tmrw how common is that the issue i searched the net and our forums and that has come up in any of the discussions. as long as i get a current thru it should it be fine or is there a certain voltage?
Also to add onto my comment from earlier after the specialist put in the freon and everything it seemed my compressor did not start moving immediately
Old Jul 4, 2017 | 06:14 PM
nfnsquared's Avatar
Go back to your "specialist" ?
Old Jul 5, 2017 | 12:33 AM
Thanks for the help a-hole ill take that into consideration you duck
Old Jul 5, 2017 | 06:10 PM
igloo's Avatar
Duck. That's funny.
Old Jul 9, 2017 | 09:11 AM
A/c compressor & cold air shuts off after a small time
I took my car to a shop to have them vacuum and put new freon in changed the acc relay, what should I be looking at next it works for maybe 5-10 mins then starts blowing outdoor air. The strength of the fan isn't any different when this happens just the temperature
Old Jul 9, 2017 | 09:23 AM
Crashmaster's Avatar
It could be freezing up. I would take it back to the shop. Often freezing up could be low on refrigerant or perhaps they used a refrigerant blend instead of R132. Many shops are doing this to make a higher profit.
Old Jul 11, 2017 | 09:09 PM
A/C pressure switch
Any one got the oem partnumber for me?
Old Jul 12, 2017 | 11:34 AM
Turbonut's Avatar
80440-SEP-A01 Triple Pressure Switch $46.48 $34.86
