A/C blows hot air.
some simple tests for finding the leak that you most likely have
A.
1. Open hood
2. Start car
3. Turn on AC
4. Go to engine and check to see if compessor is working (you will hear it click on and off an the engine change RMP at the same time)
If your compressor is NOT turing on and off do Step B
B. Get some R134a with the flourscent die in it (one of those recharge kits). Any brand will do
1. Open hood
2. Start car
3. Turn on AC
4. Connect hose to can following directions
5. Connect other end to LOW SIDE (the hose only fits the low side)
6. add just enough of the R134a with dyle to get the compressor to kick on
7. Take a LED (not the regular incadescent) flashlight and start looking for leaks while the engine is running. BE CAREFUL as there is a few moving parts that CAN SERIOUSLY MESS YOU UP
My guess is you are going to find a hole in your condensor and see the die coming out. If the condensor checks out fine, shine light at compressor and check the shaft seal. Next follow each line from compressor to fire wall and check. It is unlikely the lines will leak from the aluminum parts but more likely at the ponts where they connect to the rubber flex hose.
Take care to Acura dealer and give them $400 to replace condensor and receiver dryer or slightly less for a leaky line. Make SURE they replace the receiver / dryer unit
A.
1. Open hood
2. Start car
3. Turn on AC
1. Open hood
2. Start car
3. Turn on AC
https://acurazine.com/forums/showthread.php?t=890420
To the OP:
continuing to run the A/C compresser when it is not cooling, can damage the compresser. If the problem is no or low Freon, since the compresser lubricating oil is suspended in the Freon, then there is no oil, the compresser bearings self-destruct, and spread metallic junk throughout the entire A/C system.
That requires replacing the compresser, lines, condenser, accumulator, and if you are unlucky, the evaporator. That is why it can cost a *fortune* to 'fix' an A/C system. Its the labor that is the major cost, although the parts are not cheap either.
And sometimes its just the compresser clutch that is bad, as indicated by a recent Acura TSB for the RDX, and the extended warranty for the 1st gen RDX.
Replacing the clutch alone is only $150+ for the part, and much cheaper than replacing the compresser, since it is not necessary to disconnect the Freon lines, and replace the Freon. Of course, many shops will just want to replace the compressor (with clutch) because its easier, and much more money to their bottom-line. Use a shop that you trust, and get a second opinion.
Biggie_B
May 27, 2025 05:51 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
