Button in Key Fob Not Working?
Old Jul 31, 2008 | 04:31 PM
EPS CL's Avatar
SSM Accord V6 6 Spd
I normally don't ever post here because I don't own a TL (I own a 7th gen Accord), but I do own a TL switchblade key and the unlock button has stopped working. It's been about a year and a half that all functions on the remote worked (ignition, lock, unlock, trunk, panic) and now the unlock button doesn't work. I will repeatedly press it and the red light does not light up. The door lock actuators do work, however, leading me to believe that it's a remote issue. It was acting up a few weeks ago, requiring me to first press the lock button, then the unlock button to get it working.
I am thinking either the remote needs to be reprogrammed, have its battery replaced, or needs to be completely replaced. I've searched the forums with no luck, so if anyone can help me out I'd really appreciate it.
Old Aug 4, 2008 | 11:34 AM
Jawbone's Avatar
EPS CL
Not sure if you figured out your problem but in any case you have to replace the battery. Also you might have pressed the Lock and Unlock button at the same time which clears out your memory. All you have to do if its not a battery issue is to go to a honda dealer and have them reprogram your key. Good luck.
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
acurajj
Sep 19, 2015 03:47 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
asahrts
Sep 4, 2015 05:55 PM
