"burned" smell in cabin?
Old 12-19-2008 | 08:19 AM
05tlguy's Avatar
Hello all,
has anyone ever experienced a burned/charred smell briefly in the car? 05 tl auto? Fluids do not smell burned ....
Old 12-19-2008 | 09:40 AM
csmeance's Avatar
How fast were you going? The TL and some other cars are known for the rotten egg issue/burning issue. Basically when you are at a stand-still, and then punch the gas AFTER the car is warmed up to temp and go near 90+ MPH, the car will get a burning/egg smell in the car. Some say its due to fuel soaking the car's catalytic converters.
Old 12-19-2008 | 10:19 AM
Zigma's Avatar
Is this harmful to the car?
Old 12-19-2008 | 10:54 AM
csmeance's Avatar
not really, if it's done on a daily basis for a while (soaking the cats with fuel), their lifespan will be reduced. Acura warranties the cats until 100k
Old 12-19-2008 | 10:55 AM
01tl4tl's Avatar
yes that kind of thing is bad for the car- its not fuel soak in the cat- its sudden overtemp of the cat with high speeds and is ruining it from the inside~
Has your car had the recall install for the ps hose done?
Check your cabin air filter- behind the glovebox, and the blower fan and its resistor, especially if you run the cabin fan on high a lot
Old 12-19-2008 | 10:56 AM
01tl4tl's Avatar
cs=really- 100 now??, I thought it was still 80, you gen3 guys lost out on the trans warranty but gain on the exhaust~
Old 12-19-2008 | 01:31 PM
05tlguy's Avatar
Ive had the power steering hose done, changed the cabin air filter 4 months ago, no high speeds ect... happens after starting the car, at idle and while driving sometimes ...almost a smoky/ musty smell..
Old 12-19-2008 | 03:33 PM
csmeance's Avatar
I though it was 10/100K, maybe your right 8/80K...
Old 12-19-2008 | 03:47 PM
01tl4tl's Avatar
Is it only with the heater setting, or with ac also?
Only with fan? or with everything off it still happens?
I would take the blower motor out- its 2 or 3 screws after you get to the cabin filter
and look on the back of its mounting plate- the resistor has been known to fry on gen2, so thats a place to look
Also the electrical connector piece to the blower motor is known to suffer some overheat situation and fries itself.
If so - replace the connector and the resistor--
my info is based on gen2 but problems tend to keep occuring
Also check the rear heat from the center console- open the vent!!! If its closed, air still gets blown into it by the system, it just cant escape at the vent~
You may be cooking CDs or whatever is in the center box
vpasla1
09-17-2016 08:24 PM
LeVeL
10-18-2015 05:19 PM
merc009
09-29-2015 04:06 PM
Frathora
09-29-2015 12:29 AM
Quick Reply: "burned" smell in cabin?
