Bumper clip
Old Dec 28, 2009 | 08:28 PM
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
Bumper clip
dose anyone know under what catoergry i can find this part on delray acura i look everywhere
this is the good one
broken one
i need to change it because the body shop that fixed my car used the broken one and now my headlight dosnt fit right
i dont wanna take it back to the guy cuz he is an asshole
Old Dec 29, 2009 | 07:22 PM
2011 ZCP E92 M3!!
bump for help plz
Old Jan 3, 2010 | 10:21 AM
2011 ZCP E92 M3!!
up
Old Jan 3, 2010 | 12:31 PM
Adobeman's Avatar
The DVD-A Script Guy
Your pictures aren't clear enough for me to even see what you mean.
Here is the diagram for the headlight http://www.acuraoemparts.com/delray/...All&vinsrch=no
The assy is held in by the 3 bolts #20 and clip-on nuts #3. If you have those and a floppy light I'd say you are screwed.
Old Jan 3, 2010 | 01:46 PM
ladiesman217's Avatar
e92 335i
yea shit i have the same gap in the headlight, so where is the problem located to the actual bumper or headlight?
Old Jan 4, 2010 | 09:17 AM
2011 ZCP E92 M3!!
its not the headlight its under the hood its a part on each end that clamps the bumper pop ur hood and ull see what im talking about
Old Jan 4, 2010 | 06:36 PM
Adobeman's Avatar
Post clearer pictures and we will be able to help better.
Old Jan 4, 2010 | 06:48 PM
Piotr_W's Avatar
Maybe this help you
http://acura.bernardiparts.com/SearchOptions.aspx
Old Jan 5, 2010 | 05:20 PM
2011 ZCP E92 M3!!
no that dosnt really help but thx anyways im gona try and take out the part and see if the part number is engraved on it
Old Jan 6, 2010 | 08:17 PM
shftl's Avatar
No, there isn't a number on it. O'Reilly can get any Detroit fastener you can imagine, but they just look at you and shake their heads when you bring that in--I know, I tried it.
Two suggestions, neither of which I've tried yet all the way to conclusion:
A. Go online, google "Acura fasteners." You'll get lots of hits, but actually finding a match on a website is time-consuming.
B. What I intend to do--go to the Acura dealer's parts department and make a deal for a whole bunch of them. They've undoubtedly got them by the pound, and if they're not willing to share they can order them or tell you where to.
By the way, if you look carefully, you'll see that there are two kinds of fasteners that attach the fascia under the hood. The other one is smaller and has a screw slot. The one you've pictured is the larger one, and both ends of the car and the inner fenders are mostly fastened on with them.
Old Jan 7, 2010 | 04:40 PM
2011 ZCP E92 M3!!
^Thank you, i also asked a body shop to find out for me
Old Jan 7, 2010 | 06:04 PM
wasupdog's Avatar
My Garage not
yup, i would go into the parts department at an acura dealer like shftl said. some of the people you catch in there are knowledgeable about parts and the car blow up diagrams and will sell you individual components. i just don't know if the part/clip u guys need is attached to something bigger and if they'll break it up, but it's worth a shot to go to the stealer.
Old Jan 8, 2010 | 02:07 AM
crzygosu87's Avatar
Down for a photoshoot?
+1 ... quite frankly those pictures are horrible
Old Jan 14, 2010 | 04:31 PM
2011 ZCP E92 M3!!
yea i figured it out they said i need the whole fender to get that part even tho it can off the fender probali jusy gona check a junk yard for it
Old Jan 14, 2010 | 09:39 PM
shftl's Avatar
That's ridiculous. Buy a whole fender to get a PVC clip an inch long? I have a pretty good relationship with service and parts at the local dealer, so I'm going to take it up with them. Sounds like your dealership just wants you to go away. So--I've thought of a third way. Go to a reputable independent body shop and have them assist you. I'm continuing to assume that you need the clip, not the part of the plastic fascia that it goes through.
By the way, if you remove the front fascia as per the shop manual instructions for changing the HID bulbs you'll find that the light unit is supported underneath by a U-shaped steel band that comes up from the ballast. If you reshape the band a little you may be able to bring your light unit down into line.
Old Jan 14, 2010 | 11:59 PM
2011 ZCP E92 M3!!
^thx alot man, glad to see someone who cares ,im gona try that
quanaman
Jan 9, 2023 07:33 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
rhdune16
Sep 28, 2015 11:31 AM
