Broken transmission Mount
Old Aug 27, 2017 | 06:52 PM
siy010's Avatar
8th Gear
Hi everyone, I have a 2007 Acura TL Type S AT. I found that the transmission mount is broken, and I want to check if this is the rear upper transmission mount (50870-SEP-A92). I hope I ordered the correct replacement part. Thanks!!!
(Also, how long can I drive with this thing broken?)
Old Aug 28, 2017 | 02:06 AM
jimmyfu's Avatar
Yup that's the one. Picture is a little blurry though, how do you know it's broken? I thought mine was broken but upon inspection there were just rubber flakes sticking from the mount that turned out to be residual from the molding process.
Could probably get along for a while so long as you're not mashing the gas. It's not a hard job to do though; hardest part is removing the battery tray to get better acess.
Old Aug 28, 2017 | 12:36 PM
thisaznboi88's Avatar
poly fill that new mount
