Broken Spark plug tube?
Old Aug 11, 2012 | 11:59 PM
dingaling's Avatar
Hey all, this is for my 06 accord 6MT, but i figured i'd ask ya'll since the engine is similar...
Hey guys, I was checking on my spark plugs and noticed alot of oil in my tubes. Upon inspection, I noticed that the small piece came off the main tube. As I inspected more plugs, some had the small piece still glued on.
So is it safe to assume that these tubes are broken? or is that how its supposed to be and my oil leak is coming from somewhere else?
What could have caused the small section to come apart if this isn't normal? I'm at 71k miles on my 06 6sp. Anyone else ever have this issue?
Old Aug 12, 2012 | 12:11 AM
SpiderX1016's Avatar
I've seen that happen with spark plug tube oil leaks on older Hondas.
Replace the valve cover gaskets and spark plug tube gaskets.
You can probably just stick that coil back in and hope it doesn't misfire or you can just replace the coil. Do a valve adjustment while your at it.
Old Aug 12, 2012 | 01:27 AM
dingaling's Avatar
Do you think the bad spark plug seals caused them to break apart?
Old Aug 12, 2012 | 10:05 AM
nfnsquared's Avatar
Maybe. If none of the spark plugs were loose, it could be the seals. Or it could be a little of both (heat + oil). As long as you aren't throwing a code or noticing an erratic engine performance, I wouldn't replace the coil/s until you discover the source of the leak/s.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
