brake and ps fluid change
Have an 05 tl auto. Was wondering how much the dealer normally charges for changing the ps and brake fluid. Im at 78,000 miles right now and i don't think it has ever been changed. Im the second owner. No problems but the fluid is looking dark on both. Any suggestions would be appreciated.
3G TL/2G MDX Owner
PS flush=$140-170 as needed, but others do it maybe every 60k mi(more preventative).
Brake flush= $140-150 should be changed every 3 yrs per owner's manual.
these are acura dealer rates. at least near me.
KingKong_Dav
do it your self. cost about 70 dollars. have someone pump the brakes while you bleed it over and over until its clear. P/S flush is easy too. drain it from the P/S fluid cooler if yours is a type sex
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
