Blinking green d light
Old 04-18-2017, 09:12 AM
Melissacura's Avatar
has anyone had any other problem with the blinking light on d OTHER than transmission?
Old 04-18-2017, 09:19 AM
Received 8,711 Likes on 6,718 Posts
magic 8 ball says no
Melissacura (04-25-2017)
Old 04-18-2017, 10:26 AM
lol Melissa says I got my transmission codes read and nothing came up though .. that's why I'm confused
Old 04-18-2017, 10:32 AM
any other symptoms other than the light?
Hows your transmission fluid level and condition? When was the last time you had service done on it including pressure switches and fluid changes?
Old 04-18-2017, 01:22 PM
iWhine S/C 6MT TL
04WDPSeDaN's Avatar
Received 2,563 Likes on 1,317 Posts
Chances are, someone is trying to read OBD2 codes instead of transmission codes. If the light is flashing, there are code(s) stored.
Old 04-18-2017, 02:19 PM
Land of 10,000 lakes
nate_0022's Avatar
I had the Blinking D light last fall. It was a transmission range switch.
Old 04-18-2017, 02:50 PM
Q('.')=O
imj0257's Avatar
I remember a few months before I got rid of mine, my light did that. I had no idea what caused it, but it went away after a short while or after I would turn the car off then restart.
Old 04-18-2017, 02:58 PM
mazen222's Avatar
That means you have priority to turn! :P
Old 04-18-2017, 03:14 PM
I had the transmission codes read at a transmission shop. I thought the same thing.. the codes had to have stored. The only way I can describe it is the car just doesn't drive smooth and I'll feel like a jolt when the light starts flashing, loss of power and the RPM's will spike and then quickly go down even doing like 50 MPH. As far as the fluids ... just got the car honestly haven't had them checked yet. My info says my oil is 40%
Old 04-18-2017, 03:17 PM
That's engine oil
Old 04-18-2017, 03:54 PM
Jackass's Avatar
Spiking RPMs == transmission slipping
Check your transmission fluid. At a minimum, you probably will need to drain and replace the fluid. Possibly replace the pressure switches....and if it is really bad, replace the transmission.
Old 04-24-2017, 02:47 PM
Thank you so much to all you guys with your input !! Turned out to be a transmission range switch !!
