Battery Tested good....Now what?
Old Apr 28, 2010 | 03:16 PM
ccrun1800's Avatar
Car won't start after I make a short trip ( under a 1/4 mile ). Battery will hold juice overnight or multiple nights. The starter attempts to turn over on the times it wont start but only a little bit and not enough to get the engine to fire up. Any thoughts?
Old Apr 28, 2010 | 03:43 PM
nfnsquared's Avatar
How did you test the battery?
Battery connections? Loosen the connections, wiggle, clean, re-tighten.
Alternator? Voltage regulator? Have you had the charging system tested?
Starter?
HFL or other system draining the battery? See post #12 to test for drain:
https://acurazine.com/forums/3g-tl-problems-fixes-114/battery-drain-testing-608959/
Old Apr 28, 2010 | 05:06 PM
Jesstzn's Avatar
Check the battery terminals and the cable ends to make sure they are really clean . Even if they look clean .. clean them.
Poor ground can do that .
Was it load tested? How did you test it?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
