Battery Reset Everything!!HELP!!
Old Nov 24, 2006 | 11:38 PM
h22vtec's Avatar
I just installed my CAI(What a bitch to install) and I had to remove my battery. After I put everything back together, THE ALARM DOESNT ACTIVATE, THE RADIO IS ASKING FOR A CODE WHICH I DONT HAVE, AND I CANT USE MY BLUETOOTH. Is there any1 that can help me with this, I would really appreciate some help. Thanx!!
P.S. I dont have my Manual and its for an 04 TL.
Old Nov 25, 2006 | 01:04 AM
01tl4tl's Avatar
Simple fix
First look for a biz card from the dealer left in the glovebox with numbers written on it
Look in the glovebox or center console for a 5 digit code that someone hand wrote, thats the radio code-its part of the anti theft device built in.
If you can't find it there, remove the radio, sometimes just the side panal will give access.
Obtain the radio serial number and take it to local Acura dealer with your car registration/vin number-some type of proof its your car. They will look up the code for you at no charge.
Good luck
Old Nov 25, 2006 | 09:39 AM
h22vtec's Avatar
Thanx, ill try and see if i can find it when i get out of work.
But what about my alarm? When I hit the lock button twice, it doesnt activate, and if i open the car while its locked and the window is open, tha alarm doesnt go off. What can i do to fix this problem?
Old Nov 25, 2006 | 10:06 AM
h22vtec's Avatar
Just took a lil break from work to look for the card and found it in the glove compartment. Code fixed everything, THANX ALOT!!!
Old Nov 28, 2006 | 12:28 AM
01tl4tl's Avatar
Glad it worked out for you. Let this be a reminder to all, write the code down in permanent marker somewhere in the car- in the glovebox, on the fusebox, somewhere!!!!!! Its a pain to pull the radio and all that
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
brboy
Oct 5, 2015 11:34 AM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
