Bad week for the TL
Old Jun 11, 2011 | 10:50 AM
Resse4x's Avatar
05 6speed
Bad week for the TL
ok i was standing outside the car for about 15-20 mins talking car running all of a sudden its leaking and over heating ...so i popped the hood to find the fulids in the reservoir bubbling.... my car never over heated before.but wait there's more the fluid was blue.... ive seen green and orange antifreeze but never blue .... then the lights start to act crazy also the fogs are on very dim though even when i take the keys out and shut the lights off. when i turn the lights on ... nothing on the dash the left signal is on but not blinking as of now the only light i have is one fog light smh ...helpppppp
Old Jun 11, 2011 | 11:16 AM
cjTL's Avatar
I'm Craig
The blue fluid is Honda coolant. As for the lights acting funny...no idea. Bad battery? Only thing I could think of since your car was just idling for 20 minutes and the alternator wasn't really recharging it. Have you driven the car since?
Old Jun 11, 2011 | 12:36 PM
Resse4x's Avatar
05 6speed
the battery is a couple months old i was thinking maybe the ballast or sumthing
Old Jun 11, 2011 | 05:10 PM
ggesq's Avatar
OT- question. Can you post pics of your car? I'm interested in seeing the color.
Old Jun 11, 2011 | 05:26 PM
imj0257's Avatar
Q('.')=O
^ Looks purplish..
Old Jun 12, 2011 | 09:57 AM
Resse4x's Avatar
05 6speed
ill take some tomorrow but i warn u im using my iphone
Old Jun 12, 2011 | 10:16 AM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Your car overheated. Acura/Honda uses a BLUE extended life coolant in their vehicles. When the coolant is Green it's due for a coolant service. There could be a few things going on with your car.
Did you hear the cooling fans kick on before the overheating?-You may have a bad relay or blow fuse for the fans, or have bad fans
Next time you get your vehicle warmed up touch your coolant hoses are they both hot or one is hot the other is cold?-You may have a bad thermostat. Usually the return hose from the engine to the radiator will stay cool as the upper hose would stay hot. Thermostat suck won't allow proper flow thus improper cooling = overheating.
Did you notice any other location where coolant may leak from other than your coolant reservoir bottle?-Strong indication if coolant is leaking from the radiator that your radiator needs replacing and is packed with corrosion. Coolant service is also adviced with this type of repair. Honda/Acura coolant is 6 yr, 105k.
Old Jun 12, 2011 | 10:40 AM
ez12a's Avatar
the overexplainer
bad rad cap can also cause reservoir overflow.
mada51589
Jan 9, 2025 04:40 PM
mugen_kid
Nov 13, 2015 10:38 PM
Frathora
Sep 28, 2015 11:29 PM
Kitsune13
Sep 24, 2015 02:25 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
