axle question
2004 Acura TL
axle question
axles are being changed right now from a friend of mine and he replaced the driver side fine but can't seem to get the axle out of the transmission on the passenger side. anyone know what the problem is? need to know asap thanks
I believe the right D/S is connected to an intermediate shaft that stays in the car. Strike the right D/S at the inner CV joint to remove it from the intermediate shaft. If he is going to remove the intermediate shaft, bracket and exhaust pipe needs to be removed.
The DVD-A Script Guy
Intermediate shaft bearing and bracket. It appears to only be sold with the intermediate shaft assembly. (#18 here http://www.acuraoemparts.com/delray/...h=no)According to the service manual you drive the inboard joint off of the intermediate shaft with a drift and hammer.
Good question. Some kind of bracket, although it doesn't appear to have a parts listing. Call or PM Kaleb (WholesalePartsGuy) or contact him at Prestige Acura.
Here's the diagram for it:
http://www.acurapartswarehouse.com/P...gPicture=False
2004 Acura TL
so i would have to buy the whole assembly? which is around 200$ the bracket cracked as the kid who is replacing it for me tried to pull out the axle
If he was prying hard enough against the transaxle housing to crack the bearing support bracket, hope he didn't damage the transxle case.
Take a look over on ebay for a jack shaft assembly, example:
http://cgi.ebay.com/ebaymotors/04-05...Q5fAccessories
Look at www.car-part.com under axle, then jack shaft either AT or MT.
2004 Acura TL
i'll pm him thanks
navtool.com
31
11-16-2015 08:30 PM
spoiler900
10-10-2015 06:48 PM
navtool.com
09-25-2015 05:15 PM
