AV6 swap issues
Old May 8, 2018 | 03:35 AM
JM04TL's Avatar
AV6 swap issues
I have a 2004 TL with a bad trans. I purchased a 2007 AV6 BAYA (7RATAE6) as a replacement the shop that is doing the removal and install has informed me that the torque converter with the av6 will not work/fit the TL.
In all my searching i did not come across anything mentioning a potential issue with the converter. can anyone shed some light on this.
Old May 8, 2018 | 08:55 AM
truonghthe's Avatar
the transmission itself is a direct swap, you need to swap over the TL TQ converter (highly recommend replace with a new one) and transmission range switch.
Old May 8, 2018 | 02:00 PM
JM04TL's Avatar
Any recommendations on where to buy a new converter?
Old May 8, 2018 | 03:11 PM
rockauto.com
Old May 9, 2018 | 05:29 PM
JM04TL's Avatar
are the av6 and tl flex plates differnt?
the new TL converter is not recessed in the case of the baya and it has interference with the flex plate the fit is definitely not right. has anyone else had this issue i cant seem to find and info regarding similar issues
Old May 9, 2018 | 06:43 PM
JM04TL's Avatar
the converter will not seat into the trans case as deep as the original trans and converter the difference is about .200
we are using
2007 BAYA
NEW 04TL CONVERTER
TL FLEX PLATE
any help would be great thanks all
Secreta Manny
Mar 2, 2019 09:40 AM
michaeldove
Nov 2, 2017 03:12 PM
SatinSilverAV6
Oct 9, 2010 10:03 PM
Habib
Dec 13, 2006 09:31 PM
RidinLow
Aug 13, 2001 12:48 AM
