Auto RX
Old Apr 25, 2008 | 02:33 PM
waymay1305's Avatar
Auto RX
Does anyone recommend this? I have 62k miles on my TL. Pros and cons.
Old Apr 25, 2008 | 02:39 PM
01tl4tl's Avatar
what does it do?
The masses here like seafoam and bg44 for cleaning the intake system
The oil should not get any mileage-slippery-thickeners stuff added to it-
vtec operates on oil pressure changes, so you do want to run an engine cleaner thru the oil right before a change now and then.
In my opinion and as proved by members with over 200,000 miles onthe motor
Old Apr 25, 2008 | 04:02 PM
waymay1305's Avatar
It's supposed to clean sludge and grime from the oil system.
Old Apr 25, 2008 | 06:50 PM
01tl4tl's Avatar
may I suggest you read any of the Seafoam threads here- 1 8oz can in the engine oil before oil change will clean it right up- also used in intake mmanifold vac line, and gas tank- cleans everything
If you suspect sludge- replace the oil filter before treatment- so a fresh one can catch all the bad stuff you will dislodge.
According to their directions on website- you can drive with it in the engine as long as you closely watch the color on the dipstick and change the oil when its bad.
Many ziners run it 5 minutes at idle- others drive 15-30 minutes.
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
malvothegreat
Sep 29, 2015 12:38 AM
jmaxima03
Sep 27, 2015 10:22 AM
