Anyone know how to fix this problem with my headlight?
Old Mar 27, 2010 | 11:49 PM
big_mac65's Avatar
B-MAC
So about four months ago, I had 8000k bulbs in my TL and then one day out of the blue, the passenger side goes out. I turned my headlights back on and then the passenger side came back on. But unfortunately five minutes later, it went out again. I figured the bulb was bad and put the stock bulbs back in... Everything worked fine after that. Last week I installed some brand new 10,000k bulbs and the same thing happened as before: only the passenger light goes out after 20 minutes or so. Anyone know whats going on? Do higher Kelvin temperatures also affect the wattage of the bulbs, not just the color? Any ides as how to fix it. I NEED HELP!!!
Old Mar 28, 2010 | 12:04 AM
bforbrian's Avatar
Well from what you stated, the problem clearly isn't the bulb.
I'm pretty sure your ballast is acting up; you should get it replaced.
Old Mar 28, 2010 | 12:16 AM
big_mac65's Avatar
B-MAC
Thats what I was afraid of... anyone know off hand how much one of those would run. Car unfortunately is 6,500 miles out of warranty.
Old Mar 28, 2010 | 12:28 AM
bforbrian's Avatar
You're looking at roughly $100 for just the ballast, and around $150 for the ballast and ignitor.
http://cgi.ebay.com/ebaymotors/06-09...Q5fAccessories
Old Mar 28, 2010 | 04:35 AM
01tl4tl's Avatar
sounds like cheap aftermarket bulbs are the culprit- as stock bulbs worked without issue in between sets of replacements- is that correct OP?
4300 is stock color- 6000 is considered highest you can go and still see the road
5000k is an excellent alternative- more blue to see road markings with (it picks out the reflecto stuff in paint) but still plenty of white to see the road surface and obstacles like animals
kaixen brand are well liked at ~100 per pair- see vendors excelerate or one of the hid lighting people for those
cheap bulbs wont do well in the TL, the car seems to have a taste for expensive things,,premium gas,,great tires and brakes...
Old Mar 28, 2010 | 08:22 AM
voigt's Avatar
could it be that the aftermarket bulbs get hotter than the stock ones and there is a cuttoff built into the ballast when it reaches a certain a temp? I have no clue though.
Old Apr 20, 2010 | 02:43 PM
big_mac65's Avatar
B-MAC
For anybody who has this problem in the future...
It turns out I was sent a bad bulb. I switched the bulbs in the headlights to test if the ballast truely was the culprit and when that was done, the other headlight went out, ie... BULB WAS THE CULPRIT! Thanks to all that helped out! I dont know how anyone with a TL does without this site.
Old Apr 23, 2010 | 10:44 PM
mrlal8's Avatar
im having the same problem as u...i sent u a pm about whats going on with my bulb except its the drivers side...
if anyone else has had this problem what shud i do?
is it the bulb thats causing the problem?
tman570
Jun 11, 2019 07:56 AM
NJALLDAY57
Oct 13, 2015 08:25 AM
JnC
Sep 11, 2015 06:06 AM
Phambam12
Sep 6, 2015 06:57 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
